楼主: shadowba
[经验分享] 更新简单教程-魔百盒M401A成功安装Home Assistant Supervisor
发表于 2022-7-11 11:58:26 | 显示全部楼层
香香的!!!
Xi11 手机认证
发表于 2022-7-11 15:57:39 | 显示全部楼层
FDT /dtb/amlogic/meson-g12a-s905l3a-e900v22c.dtb
APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
extlinux.conf文件改成这样是否正确?meson-g12a-s905l3a-e900v22c.dtb拷贝到\dtb\amlogic目录下。修改u-boot-s905x-s912文件名改成U-boot.ext。大神帮忙看看这样配置对吗?谢谢!
 楼主| 发表于 2022-7-11 16:18:28 | 显示全部楼层
APPEND root=LABEL=ROOTFS rootflags=data=writeback ...
LABEL Armbian
LINUX /zImage
INITRD /uInitrd
# rk-3399
#FDT /dtb/rockchip/rk3399-rock-pi-4.dtb
#FDT /dtb/rockchip/rk3399-nanopc-t4.dtb
#FDT /dtb/rockchip/rk3399-roc-pc-mezzanine.dtb
#APPEND root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=uart8250,mmio32,0xff1a0000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
# rk-3328
#FDT /dtb/rockchip/rk3328-roc-pc.dtb
#FDT /dtb/rockchip/rk3328-box-trn9.dtb
#FDT /dtb/rockchip/rk3328-box.dtb
#APPEND root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=uart8250,mmio32,0xff130000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
# aw h6
#FDT /dtb/allwinner/sun50i-h6-tanix-tx6.dtb
#APPEND root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=ttyS0,115200 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 video=HDMI-A-1:e
#APPEND root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=ttyS0,115200 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mem=2048M video=HDMI-A-1:e
# aml s9xxx
#FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb
#FDT /dtb/amlogic/meson-gxm-q200.dtb
#FDT /dtb/amlogic/meson-g12a-x96-max.dtb
#FDT /dtb/amlogic/meson-g12b-odroid-n2.dtb
APPEND root=LABEL=ROOT_EMMC rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
发表于 2022-7-13 07:57:47 | 显示全部楼层
一定要ttl启动嘛,我看有些教程上说什么按住重启和遥控右键也行,别的固件不用拆机就能启动
Xi11 手机认证
发表于 2022-7-13 09:31:51 | 显示全部楼层
大佬,再打扰一下,写入emmc用哪条指令?[size=1em]./install-aml.sh吗?
发表于 2022-7-13 11:23:38 | 显示全部楼层
感谢教程,去淘个玩玩
 楼主| 发表于 2022-7-13 12:06:53 | 显示全部楼层
Xi11 发表于 2022-7-13 09:31
大佬,再打扰一下,写入emmc用哪条指令?./install-aml.sh吗?
ls查看一下目录,里面有一个,具体我给忘了
发表于 2022-7-13 12:38:32 | 显示全部楼层
TTL链接机顶盒 根本没显示啊  我这个是不一样?
 楼主| 发表于 2022-7-13 12:48:24 | 显示全部楼层
用PUTTY,选择你转接设备的COM口,rx与tx要交叉连接,然后开机就会显示
发表于 2022-7-13 15:00:01 | 显示全部楼层
我买的这个m401a不会 试了很多次 接不接3v3都试了 开始按不按重置键也试了  putty一直按回车也试了恢复菜单我甚至都进了 但是电脑上usb buring tool 链接上就失败
GMT+8, 2026-1-17 13:56 , Processed in 0.439927 second(s), 12 queries , MemCached On.
