查看: 2041|回复: 1
[技术探讨] 出现好多关于Zigbee2MQTT 的错误日志,求助
发表于 2022-6-27 20:55:39 | 显示全部楼层 |阅读模式
前段时间没太记得是升级ha还是升级ZigBee2mqtt了,升级完以后发现多了许多错误日志,当时也没太在意,后来又升级了几个版本,发现系统日志里不断的反复的在报下面这个日志。目前的版本是
Home Assistant Core
2022.6.7,
Home Assistant Supervisor
2022.05.3,
Home Assistant OS
8.2,
Zigbee2MQTT 1.25.2-1
有知道是怎么回事的吗?
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'external_converters' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'devices' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'groups' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'homeassistant' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'permit_join' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'advanced' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'device_options' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'blocklist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'passlist' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'queue' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'frontend' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-06-27 20:40:45 WARNING (MainThread) [supervisor.addons.options] Option 'experimental' does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
 楼主| 发表于 2022-6-28 21:53:51 | 显示全部楼层
哎,日常一顶
GMT+8, 2026-1-18 23:28 , Processed in 0.246045 second(s), 8 queries , MemCached On.
