楼主: dscao
[插件集成] 钉钉群机器人和企业微信群机器人+企业微信论坛修改加强版
发表于 2023-12-3 20:50:27 | 显示全部楼层
看看
顶顶顶顶顶顶顶
jole 手机认证
发表于 2023-12-29 16:40:43 | 显示全部楼层
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:226
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 下午4:39:22 (1 occurrences)
Last logged: 下午4:39:22
[139712751933248] Expecting value: line 1 column 1 (char 0)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 226, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2012, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2049, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 264, in _async_notify_message_service
    await self.async_send_message(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 240, in async_send_message
    await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/wework_notify/notify.py", line 97, in send_message
    + self.get_access_token()
  File "/config/custom_components/wework_notify/notify.py", line 91, in get_access_token
    self._token = self._get_access_token()
  File "/config/custom_components/wework_notify/notify.py", line 80, in _get_access_token
    data = json.loads(req.text)
  File "/usr/local/lib/python3.11/json/__init__.py", line 346, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.11/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.11/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
大佬,这是哪里报错了??
lozn 手机认证
发表于 2024-1-11 11:11:09 | 显示全部楼层
下载不了
发表于 2024-5-8 11:17:17 | 显示全部楼层
哥,有没有钉钉企业机器人的接入插件啊
发表于 2024-7-17 21:59:14 | 显示全部楼层
现在还能用吗?
发表于 2024-9-8 12:15:03 | 显示全部楼层
谢谢,太复杂了
发表于 2024-9-9 21:11:49 | 显示全部楼层
大佬,小白请教一下企业微信的配置代码需要放到哪个文件里面?
发表于 2024-9-11 18:11:04 | 显示全部楼层
大佬,指导一下。如何配置:当我不在家,家中任何一盏灯被打开时,通过钉钉给我发通知。  钉钉机器人已配置好
发表于 2024-9-12 20:22:44 | 显示全部楼层
试试看看,需要的
ike 手机认证
发表于 2025-9-4 16:10:20 | 显示全部楼层
感谢分享,但是不会用,学习学习
GMT+8, 2026-1-14 14:37 , Processed in 0.994129 second(s), 12 queries , MemCached On.
