查看: 6301|回复: 12
[技术探讨] 如何禁用 homepod mini 发的 icmpv6 路由广播
发表于 2022-6-25 15:54:13 | 显示全部楼层 |阅读模式
windows 下 ipconfig ,总是发现 fd41 打头的地址,
无线局域网适配器 WLAN:
   连接特定的 DNS 后缀 . . . . . . . : N1.lan
   IPv6 地址 . . . . . . . . . . . . : 2408:xx:xx:xx::2
   IPv6 地址 . . . . . . . . . . . . : 2408:xx:xx:xx:yy:yy:yy:yy
   IPv6 地址 . . . . . . . . . . . . : fd41:9bf9:7ed3:4944:yy:yy:yy:yy
   临时 IPv6 地址. . . . . . . . . . : 2408:xx:xx:xx:4c6d:a1ca:31c2:c258
   临时 IPv6 地址. . . . . . . . . . : fd41:9bf9:7ed3:4944:4c6d:a1ca:31c2:c258
   本地链接 IPv6 地址. . . . . . . . : fe80::yy:yy:yy:yy%10
   IPv4 地址 . . . . . . . . . . . . : 192.168.1.99
   子网掩码  . . . . . . . . . . . . : 255.255.255.0
   默认网关. . . . . . . . . . . . . : fe80::3%10
                                       192.168.1.2
查了半天,抓包发现是homepod的
[root@x6 /mnt/jffs2/hw] # tcpdump  -i any  icmp6 and 'ip6[40] = 134'
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
07:47:31.152843 IP6 fe80::3 > ff02::1: ICMP6, router advertisement, length 64
07:47:31.152874 IP6 fe80::3 > ff02::1: ICMP6, router advertisement, length 64
07:47:31.152915 IP6 fe80::3 > ff02::1: ICMP6, router advertisement, length 64
07:47:31.152923 IP6 fe80::3 > ff02::1: ICMP6, router advertisement, length 64
07:47:31.153116 IP6 fe80::3 > ff02::1: ICMP6, router advertisement, length 64
07:47:31.906790 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
07:47:31.906814 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
07:47:46.660355 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
07:47:46.660392 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
07:47:46.660449 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
07:47:46.660463 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
07:47:46.660564 IP6 fe80::xx:xx:xx:xx > ff02::1: ICMP6, router advertisement, length 72
fe80::3 是主路由,fe80::xx:xx:xx:xx是 homepod mini
有人知道如何禁用
发表于 2022-6-25 17:12:48 | 显示全部楼层
https://discussions.apple.com/thread/253574639
https://discussions.apple.com/thread/252367920
查了下好像是为了 Thread 组网?
苹果:“你家的网络是我的。
 楼主| 发表于 2022-6-25 22:55:46 | 显示全部楼层
估计无解了
发表于 2022-6-27 09:43:07 来自手机 | 显示全部楼层
按道理可以,交换机或路由禁止 HomePod 发出的  RA 流量通过 mac 限制。
 楼主| 发表于 2022-6-27 09:59:31 | 显示全部楼层
广播信息,貌似只能通过 mac 过滤,回头我看看能不能通过iptables 在路由器上过滤下 forward 数据。
发表于 2022-6-27 10:29:30 | 显示全部楼层
ciasdmxhxjjpd@c 发表于 2022-6-27 09:59
广播信息,貌似只能通过 mac 过滤,回头我看看能不能通过iptables 在路由器上过滤下 forward 数据。 ...
是组播,好像是 ip6table 限制 但我没实操过,建议配合抓包工具尝试一下。
 楼主| 发表于 2022-6-28 07:36:29 | 显示全部楼层
关闭了光猫上的组播,依旧,
在ma5671 (205固件 )光猫上执行
WAP(Dopra Linux) # ip6tables -I FORWARD  -m mac --mac-source 94:EA:32:xx:xx:xx -j REJECT
ip6tables: No chain/target/match by that name.
估计 内核编译时,没有使能 iptables mac
发表于 2022-6-28 09:02:34 | 显示全部楼层
ciasdmxhxjjpd@c 发表于 2022-6-28 07:36
关闭了光猫上的组播,依旧,
在wifi那边写上这句,从wifi那边禁止homepod 往外发 RA报文。
ip6tables -I FORWARD -s <这里写你homepod的ipv6本地链路地址如: fe80::1/128> -p ipv6-icmp -m icmp6 --icmpv6-type 134 -j DROP
 楼主| 发表于 2022-6-28 09:39:40 | 显示全部楼层
wifi 上没有用,因为我是光猫拨号,v6的路由在光猫上,
forward 链 涉及到路由。
还有,组播是广播信息?不经过路由?发给每个客户端?
发表于 2022-6-28 13:42:18 | 显示全部楼层
forward 链 涉及到路由。
你的 RA 是 homepod 发出来的吧 。不是路由转发的。
你自己抓包都看到了 ff02::1 是组播地址,它发出 router advertisement 公告啊。
GMT+8, 2026-1-18 22:02 , Processed in 0.243162 second(s), 4 queries , MemCached On.
