查看: 2733|回复: 0
[求助] python语句怎么操作homeAssistant实体
发表于 2022-6-18 19:20:02 | 显示全部楼层 |阅读模式
设备是通过易微联加进homeassistant  产生 switch.10000890的实体
1.由于版本更新快 这样的语句是否还有效2.易微联加进去的设备 是不是操作指令不一样
if self.execute_service(entity_id, url, port, headers, act):
                                if not has_execute:
                                    self.say("设备执行成功", cache=True)
                                    has_execute = True
                            else:
                                if not has_execute:
                                    self.say("对不起,设备执行失败", cache=True)
                                    has_execute = True
def execute_service(self, entity_id, url, port, headers, act):
        p = json.dumps({"entity_id": entity_id})
        domain = entity_id.split(".")[0]
        s = "/api/services/" + domain + "/"
        url_s = url + ":" + port + s + act
        request = requests.post(url_s, headers=headers, data=p)
        if format(request.status_code) == "200" or \
           format(request.status_code) == "201":
            return True
        else:
            logger.error(format(request.status_code))
            return False
GMT+8, 2025-12-25 10:41 , Processed in 0.550472 second(s), 12 queries , MemCached On.
