查看: 3522|回复: 5
[求助] samba share无法连接
发表于 2022-6-11 23:37:43 | 显示全部楼层 |阅读模式
小白入坑,Samba Share下载启动之后报错,无法连接,有老哥知道怎么解决吗,万分感谢下面是日志
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.[cont-init.d] executing container initialization scripts...
[cont-init.d] samba.sh: executing...
[23:35:45] INFO: [color=var(--success-color)]Hostname: null
[23:35:46] FATAL: [color=var(--error-color)]No supported interfaces found to bind on.
[cont-init.d] samba.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
3万
发表于 2022-6-11 23:55:00 | 显示全部楼层
先检查一下:
配置——系统——网络——Network Adapter 的设置
不行再仔细看看这里有没有解决方法吧:
https://community.home-assistant ... led-samba/416362/23
发表于 2022-6-12 00:25:21 来自手机 | 显示全部楼层
把配置参数发出来看看有没有填错
 楼主| 发表于 2022-6-12 00:36:28 | 显示全部楼层
tiani 发表于 2022-6-12 00:25
把配置参数发出来看看有没有填错
username: hassos
password: abc123
workgroup: WORKGROUP
compatibility_mode: true
veto_files:
  - ._*
  - .DS_Store
  - Thumbs.db
  - icon?
  - .Trashes
allow_hosts:
  - 10.0.0.0/8
  - 172.16.0.0/12
  - 192.168.0.0/16
  - fe80::/10
interface: eth0
发表于 2022-6-12 03:08:22 | 显示全部楼层
lbbjzz 发表于 2022-6-12 00:36
username: hassos
password: abc123
试试这个。
username: hassospassword: 'abc123'workgroup: WORKGROUPcompatibility_mode: falseveto_files:  - ._*  - .DS_Store  - Thumbs.db  - icon?  - .Trashesallow_hosts:  - 10.0.0.0/8  - 172.16.0.0/12  - 192.168.0.0/16  - fe80::/10
 楼主| 发表于 2022-6-12 14:35:00 | 显示全部楼层
试过了,不管用哇
GMT+8, 2025-11-5 13:56 , Processed in 1.275349 second(s), 10 queries , MemCached On.
