查看: 2892|回复: 5
[求助] homeassistant升级2002.06之后无法启动
发表于 2022-6-8 13:49:32 | 显示全部楼层 |阅读模式
早上homeassistant升级2002.06之后无法启动 以下为报错。麻烦大神看看
一键hassio的
[05:42:06] INFO: Home Assistant Core finish process exit code 1
[05:42:06] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
[05:42:06] INFO: Home Assistant Core finish process exit code 256
[05:42:06] INFO: Home Assistant Core finish process received signal 15
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
services-up: info: copying legacy longrun home-assistant (no readiness notification)
2022-06-08 13:43:27 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/configuration.yaml contains duplicate key "automation". Check lines 16 and 21
2022-06-08 13:43:27 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration havcs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ha_file_explorer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration zhicaiyun which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration colorfulclouds which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ha_sidebar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miio_plug which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hasslife which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration molobot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration xiaomi_miio_philipslight which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration xiaomi_miot_raw which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration zhibot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs_proxy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (SyncWorker_6) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-06-08 13:43:27 WARNING (MainThread) [homeassistant.config] Key whitelist_external_dirs has been replaced with allowlist_external_dirs. Please update your config
2022-06-08 13:43:27 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for hacs_proxy:  we are unable to resolve (sub)dependency hacs
[05:43:28] INFO: Home Assistant Core finish process exit code 1
[05:43:28] INFO: Home Assistant Core service shutdown
[05:43:28] INFO: Home Assistant Core finish process exit code 256
[05:43:28] INFO: Home Assistant Core finish process received signal 15
pi@raspberrypi:/h/hassio/homeassistant/custom_components $ docker ps -a
CONTAINER ID   IMAGE                                                        COMMAND    CREATED          STATUS                        PORTS                                   NAMES
946b7e2a66ca   ghcr.io/home-assistant/raspberrypi4-homeassistant:2022.6.2   "/init"    22 minutes ago   Exited (143) 5 minutes ago                                            homeassistant
1626679c9754   ghcr.io/home-assistant/armv7-hassio-multicast:2022.02.0      "/init"    23 minutes ago   Up 23 minutes                                                         hassio_multicast
91a6b0afbfc9   ghcr.io/home-assistant/armv7-hassio-audio:2022.05.0          "/init"    23 minutes ago   Up 23 minutes                                                         hassio_audio
c796487f5f15   ghcr.io/home-assistant/armv7-hassio-dns:2022.04.1            "/init"    23 minutes ago   Up 23 minutes                                                         hassio_dns
07e5b32fb600   ghcr.io/home-assistant/armv7-hassio-cli:2022.05.0            "/init"    23 minutes ago   Up 23 minutes                                                         hassio_cli
f811f19946c2   68f26a0f284a                                                 "/init"    25 minutes ago   Exited (111) 25 minutes ago                                           suspicious_davinci
388e088a931e   mzz2017/v2raya                                               "v2raya"   2 days ago       Up 23 minutes                                                         v2raya
af0f9ad1bd5c   homeassistant/armv7-hassio-supervisor                        "/init"    2 weeks ago      Up 23 minutes                                                         hassio_supervisor
e2c34f739808   ghcr.io/home-assistant/armv7-hassio-observer:2021.10.0       "/init"    7 months ago     Up 23 minutes                 0.0.0.0:4357->80/tcp, :::4357->80/tcp   hassio_observer
发表于 2022-6-8 16:54:51 | 显示全部楼层
现在不是配置出错可以进到安全模式么
发表于 2022-6-8 19:51:56 来自手机 | 显示全部楼层
楼主的hassio是安装在什么设备上呢?docker方式安装吗
 楼主| 发表于 2022-6-9 00:05:22 | 显示全部楼层
树莓派  docker的
发表于 2022-6-9 00:29:35 | 显示全部楼层
wsswps 发表于 2022-6-9 00:05
树莓派  docker的
树莓派是官方支持硬件,貌似可以直接官方镜像安装hassio,全功能的。
莫非您将树莓派用于多用途所以用docker方式,类似斐讯N1的用法么?
我现在斐讯N1 openwrt旁路由,HA,这两个都是docker方式。
 楼主| 发表于 2022-6-9 21:27:30 | 显示全部楼层
对 我是多用途。脚本一键安装的
在更新之前做了备份。现在恢复备份正常
应该是更新hacs商店后导致的异常。
GMT+8, 2025-12-21 15:36 , Processed in 0.608716 second(s), 11 queries , MemCached On.
