查看: 2147|回复: 3
[插件集成] [Blueprint] 小米/绿米魔方玩具 (Z2M) 自动化蓝图
发表于 2022-6-1 13:39:08 | 显示全部楼层 |阅读模式
xiaomi_cube_controller_z2m.yaml
blueprint:
  name: Aqara Magic Cube (Z2M)
  description: Control anything using Aqara Magic Cube (Z2M) - V1.2
  domain: automation
  input:
    remote:
      description: Magic Cube to use
      selector:
        entity:
          integration: mqtt
          domain: sensor
    slide_face_0:
      name: Slide the cube with face 0 up
      default: []
      selector:
        action: {}
    doubletap_face_0:
      name: Double tap the cube with face 0 up
      default: []
      selector:
        action: {}
    flipped90_face_0:
      name: Flip the cube 90 degrees to face 0
      default: []
      selector:
        action: {}
    flipped180_face_0:
      name: Flip the cube 180 degrees to face 0
      default: []
      selector:
        action: {}
    rotate_cw_face_0:
      name: Rotate cube clockwise with face 0 up
      default: []
      selector:
        action: {}
    rotate_ccw_face_0:
      name: Rotate cube counter clockwise with face 0 up
      default: []
      selector:
        action: {}
    slide_face_1:
      name: Slide the cube with face 1 up
      default: []
      selector:
        action: {}
    doubletap_face_1:
      name: Double tap the cube with face 1 up
      default: []
      selector:
        action: {}
    flipped90_face_1:
      name: Flip the cube 90 degrees to face 1
      default: []
      selector:
        action: {}
    flipped180_face_1:
      name: Flip the cube 180 degrees to face 1
      default: []
      selector:
        action: {}
    rotate_cw_face_1:
      name: Rotate cube clockwise with face 1 up
      default: []
      selector:
        action: {}
    rotate_ccw_face_1:
      name: Rotate cube counter clockwise with face 1 up
      default: []
      selector:
        action: {}
    slide_face_2:
      name: Slide the cube with face 2 up
      default: []
      selector:
        action: {}
    doubletap_face_2:
      name: Double tap the cube with face 2 up
      default: []
      selector:
        action: {}
    flipped90_face_2:
      name: Flip the cube 90 degrees to face 2
      default: []
      selector:
        action: {}
    flipped180_face_2:
      name: Flip the cube 180 degrees to face 2
      default: []
      selector:
        action: {}
    rotate_cw_face_2:
      name: Rotate cube clockwise with face 2 up
      default: []
      selector:
        action: {}
    rotate_ccw_face_2:
      name: Rotate cube counter clockwise with face 2 up
      default: []
      selector:
        action: {}
    slide_face_3:
      name: Slide the cube with face 3 up
      default: []
      selector:
        action: {}
    doubletap_face_3:
      name: Double tap the cube with face 3 up
      default: []
      selector:
        action: {}
    flipped90_face_3:
      name: Flip the cube 90 degrees to face 3
      default: []
      selector:
        action: {}
    flipped180_face_3:
      name: Flip the cube 180 degrees to face 3
      default: []
      selector:
        action: {}
    rotate_cw_face_3:
      name: Rotate cube clockwise with face 3 up
      default: []
      selector:
        action: {}
    rotate_ccw_face_3:
      name: Rotate cube counter clockwise with face 3 up
      default: []
      selector:
        action: {}
    slide_face_4:
      name: Slide the cube with face 4 up
      default: []
      selector:
        action: {}
    doubletap_face_4:
      name: Double tap the cube with face 4 up
      default: []
      selector:
        action: {}
    flipped90_face_4:
      name: Flip the cube 90 degrees to face 4
      default: []
      selector:
        action: {}
    flipped180_face_4:
      name: Flip the cube 180 degrees to face 4
      default: []
      selector:
        action: {}
    rotate_cw_face_4:
      name: Rotate cube clockwise with face 4 up
      default: []
      selector:
        action: {}
    rotate_ccw_face_4:
      name: Rotate cube counter clockwise with face 4 up
      default: []
      selector:
        action: {}
    slide_face_5:
      name: Slide the cube with face 5 up
      default: []
      selector:
        action: {}
    doubletap_face_5:
      name: Double tap the cube with face 5 up
      default: []
      selector:
        action: {}
    flipped90_face_5:
      name: Flip the cube 90 degrees to face 5
      default: []
      selector:
        action: {}
    flipped180_face_5:
      name: Flip the cube 180 degrees to face 5
      default: []
      selector:
        action: {}
    rotate_cw_face_5:
      name: Rotate cube clockwise with face 5 up
      default: []
      selector:
        action: {}
    rotate_ccw_face_5:
      name: Rotate cube counter clockwise with face 5 up
      default: []
      selector:
        action: {}
    shake:
      name: Shake the cube
      default: []
      selector:
        action: {}
    fall:
      name: Drop the cube
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/z2m-xiaomi-cube-controller/263006
mode: queued
max: 5
max_exceeded: silent
trigger:
- platform: state
  entity_id: !input 'remote'
condition:
  - condition: and
    conditions:
      - condition: template
        value_template: >-
          {{ trigger.from_state.state in ('rotate_right', 'rotate_left', 'flip90', 'flip180', 'slide', 'tap', 'shake', 'fall') }}
action:
- variables:
    event: '{{ trigger.from_state.state }}'
    sub_event: '{{ trigger.from_state.attributes.side }}'
- service: system_log.write
  data:
    level: info
    message: 'Blueprint Script: {{ event }} {{ sub_event }}'
- choose:
  - conditions: '{{ event == "slide" }}'
    sequence:
    - choose:
      - conditions: '{{ sub_event == 0 }}'
        sequence: !input 'slide_face_0'
      - conditions: '{{ sub_event == 1 }}'
        sequence: !input 'slide_face_1'
      - conditions: '{{ sub_event == 2 }}'
        sequence: !input 'slide_face_2'
      - conditions: '{{ sub_event == 3 }}'
        sequence: !input 'slide_face_3'
      - conditions: '{{ sub_event == 4 }}'
        sequence: !input 'slide_face_4'
      - conditions: '{{ sub_event == 5 }}'
        sequence: !input 'slide_face_5'
  - conditions: '{{ event == "tap" }}'
    sequence:
    - choose:
        sequence: !input 'doubletap_face_0'
        sequence: !input 'doubletap_face_1'
        sequence: !input 'doubletap_face_2'
        sequence: !input 'doubletap_face_3'
        sequence: !input 'doubletap_face_4'
        sequence: !input 'doubletap_face_5'
  - conditions: '{{ event == "flip90" }}'
    sequence:
    - choose:
        sequence: !input 'flipped90_face_0'
        sequence: !input 'flipped90_face_1'
        sequence: !input 'flipped90_face_2'
        sequence: !input 'flipped90_face_3'
        sequence: !input 'flipped90_face_4'
        sequence: !input 'flipped90_face_5'
  - conditions: '{{ event == "flip180" }}'
    sequence:
    - choose:
        sequence: !input 'flipped180_face_0'
        sequence: !input 'flipped180_face_1'
        sequence: !input 'flipped180_face_2'
        sequence: !input 'flipped180_face_3'
        sequence: !input 'flipped180_face_4'
        sequence: !input 'flipped180_face_5'
  - conditions: '{{ event == "rotate_right" }}'
    sequence:
    - choose:
        sequence: !input 'rotate_cw_face_0'
        sequence: !input 'rotate_cw_face_1'
        sequence: !input 'rotate_cw_face_2'
        sequence: !input 'rotate_cw_face_3'
        sequence: !input 'rotate_cw_face_4'
        sequence: !input 'rotate_cw_face_5'
  - conditions: '{{ event == "rotate_left" }}'
    sequence:
    - choose:
        sequence: !input 'rotate_ccw_face_0'
        sequence: !input 'rotate_ccw_face_1'
        sequence: !input 'rotate_ccw_face_2'
        sequence: !input 'rotate_ccw_face_3'
        sequence: !input 'rotate_ccw_face_4'
        sequence: !input 'rotate_ccw_face_5'
  - conditions: '{{ event == "shake" }}'
    sequence: !input 'shake'
  - conditions: '{{ event == "fall" }}'
    sequence: !input 'fall'
发表于 2022-6-1 15:53:40 | 显示全部楼层
好强!!!
发表于 2022-6-1 19:02:43 | 显示全部楼层
好强!!!
发表于 2022-7-13 09:17:57 | 显示全部楼层
这个是怎么用的
GMT+8, 2025-12-13 03:30 , Processed in 0.867710 second(s), 8 queries , MemCached On.
