查看: 2076|回复: 0
[进阶教程] 为何有的zigbee设备会注册2次?
发表于 2022-6-1 08:35:14 | 显示全部楼层 |阅读模式
日志如下:
2022-06-01 00:30:34 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: sensor 0x00158d00047b45ee power
2022-06-01 00:30:34 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: sensor 0x00158d00047b45ee energy
2022-06-01 00:30:34 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: sensor 0x00158d00047b45ee temperature
2022-06-01 00:30:34 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: sensor 0x00158d00047b45ee voltage
2022-06-01 00:30:34 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: sensor 0x00158d00047b45ee linkquality
2022-06-01 00:30:34 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: sensor 0x00158d00047b45ee update_state
2022-06-01 00:30:35 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: binary_sensor 0x00158d00047b45ee update_available
2022-06-01 00:30:35 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: switch 0x00158d00047b45ee switch
2022-06-01 00:30:35 INFO (MainThread) [homeassistant.components.mqtt.discovery] Found new component: switch 0x00158d00047b45ee switch_power_outage_memory
2022-06-01 00:30:37 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.mqtt entity: sensor.0x00158d00047b45ee_power_2
2022-06-01 00:30:37 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.mqtt entity: sensor.0x00158d00047b45ee_energy_2
2022-06-01 00:30:37 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.mqtt entity: sensor.0x00158d00047b45ee_temperature_2
2022-06-01 00:30:38 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.mqtt entity: switch.0x00158d00047b45ee_2
2022-06-01 00:30:38 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new switch.mqtt entity: switch.0x00158d00047b45ee_power_outage_memory_2
2022-06-01 00:35:11 INFO (Recorder) [homeassistant.components.sensor.recorder] Compiling initial sum statistics for sensor.0x00158d00047b45ee_energy_2, zero point set to 0.04
设备名称就变成了原来的_2,导致在HASS里面原来的设备就是灰色了,请教下如何解决呢?
GMT+8, 2025-12-2 03:29 , Processed in 0.116196 second(s), 7 queries , MemCached On.
