查看: 3299|回复: 7
[智能音箱] 小爱同学 ttl 无权限 求救 求大佬指点
发表于 2022-5-31 11:57:47 | 显示全部楼层 |阅读模式
reboot
passwd: unknown user reboot
root@(none):/# reboot
reboot
root@(none):/# [  547.386774@0] reboot: Restarting system(init)
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State ON
INFO:      AffInst: Level 0, MPID 0x2, State ON
INFO:      AffInst: Level 0, MPID 0x3, State ON
bl31 reboot reason: 0xd
bl31 reboot reason: 0x1
system cmd  1.
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318COC:3;RCY:0;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
TE: 26910
BL2 Built : 18:43:23, Sep  8 2017.
gxl g5190619 - xiaobo.gu@droid12
rn5t618_power_init
Board ID = 0
CPU clk: 1200MHz
DQS calibration enabled
DDR scramble enabled
DDR3 chl: Rank0 @ 792MHz
af_vref ddr_training_win: rank: 0 25 00 56 4a 15 80 1e 00 50 4f 1b 83 1e 00 50 4d 17 83 25 00 58 47 12 7d 579  rank: 1 36 00 56 0e 15 80 37 00 50 13 1b 83 37 00 50 12 17 83 36 00 58 0c 12 7d 584
af_vref ddr_bist_window:  rank: 0 23 01 47 37 20 63 1c 05 3f 3b 28 63 1c 02 41 39 22 63 23 01 42 35 20 62 584   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
read start page:00000000
page :00000500
succeed in getting one bbt block!
page :00000540
page :00000580
page :000005c0
select bbt block:00000014
select page:00000001
select page:00000000
bbt status: 00000000000000000000000000000000
Load fip header from NAND, src: 0x00020000, des: 0x01400000, size: 0x00004000
read start page:00000041
New fip structure!
Load bl30 from NAND, src: 0x00024000, des: 0x01100000, size: 0x0000d600
read start page:00000049
Load bl31 from NAND, src: 0x00034000, des: 0x05100000, size: 0x00017400
read start page:00000069
Load bl33 from NAND, src: 0x0004c000, des: 0x01000000, size: 0x00081c00
read start page:00000099
NOTICE:  BL3-1: v1.0(debug):2da3090
NOTICE:  BL3-1: Built : 16:05:52, Jan 19 2017
aml log : bl31 normal boot !
mpu_config_enablek
[Image: gxl_v1.1.3170-f392be9 2017-01-04 10:51:57 yun.cai@droid06]
OPS=0xf2
ab 9f 1c 6 ec 6d 7a 2e 23 aa 61 f6 [0.491424 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g85a2387-dirty (Sep 19 2017 - 19:00:12)
DRAM:  256 MiB
Relocation Offset is: 0ef38000
register usb cfg[0][1] = 000000000ffa1290
NAND:  nand id: 152 218
256MiB, SLC, page size: 2048, OOB size: 64
Creating 1 MTD partitions on "A revision NAND 2Gib TC58BVG1S3HTA00 ":
0x000000000000-0x000000200000 : "nandboot"
nand id: 152 218
Creating 5 MTD partitions on "A revision NAND 2Gib TC58BVG1S3HTA00 ":
0x000000800000-0x000001800000 : "boot0"
0x000001800000-0x000002800000 : "boot1"
0x000002800000-0x000008800000 : "system0"
0x000008800000-0x00000e840000 : "system1"
0x00000e840000-0x000010000000 : "data"
MMC:   In:    serial
Out:   serial
Err:   serial
[burnup]Rd:Up sz 0x800 to align 0x1000
[burnup]run cmd[store  read boot1 0x1000000  0x0  0x1000]
[burnup]Read end.
[burnup]run cmd[store  read boot1 0x1982000  0x982000  0x8000]
[burnup]Read end.
amlkey_init() enter!
amlkey_init() storagekey_info.buffer=0000000005080000, storagekey_info.size = 7ffc!
[KM]Error:f[key_unify_init]L177evice[1] init failed, err=-22
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
Saving Environment to aml-storage...
[burnup]run cmd[store  read boot0 0x1080000  0x0  0x100000]
[burnup]Read end.
[burnup]Rd:Up sz 0x889dbe to align 0x1000
[burnup]run cmd[store  read boot0 0x1180000  0x100000  0x88a000]
[burnup]Read end.
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
load dtb from 0x1000000 ......
   Loading Kernel Image(COMP_NONE) ... OK
   kernel loaded at 0x01080000, end = 0x018bbc88
[rsvmem] no check for rsvmem, should check int kernel
   Loading Ramdisk to 0bde1000, end 0bf26244 ... OK
   Loading Device Tree to 000000000bdd6000, end 000000000bde0dbd ... OK
Starting kernel ...
uboot time: 1366369 us
[    0.136629@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb4)
[    0.139099@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb4)
[    0.147333@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb4)
[    0.155198@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb4)
domain-0 init dvfs: 4
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
WARNING: Unimplemented Sip Call: 0x82000036
[ get key is 0x00 , curr_boot is boot0
Booting from boot0
UBI device number 0, total 768 LEBs (97517568 bytes, 93.0 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
/dev/mtd3 is ready now.
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
f
Please press Enter to activate this console.
BusyBox v1.23.2 (2018-06-07 09:10:04 UTC) built-in shell (ash)
  _______                     ________        __
|       |.-----.-----.-----.|  |  |  |.----.|  |_
|   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
|_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
CHAOS CALMER (Chaos Calmer, unknown)
  * 1 1/2 oz Gin            Shake with a glassful
  * 1/4 oz Triple Sec       of broken ice and pour
  * 3/4 oz Lime Juice       unstrained into a goblet.
  * 1 1/2 oz Orange Juice
  * 1 tsp. Grenadine Syrup
root@(none):/# [    6.343320@1] compat: exports duplicate symbol woken_wake_function (owned by kernel)
ubiformat /dev/mtd6
libmtd: error!: cannot get information about "/dev/mtd6"
        error 2 (No such file or directory)
ubiformat: error!: cannot get information about "/dev/mtd6"
root@mico:/#
 楼主| 发表于 2022-5-31 12:03:22 | 显示全部楼层
按ctrl+c 没反应
发表于 2022-5-31 23:51:57 | 显示全部楼层
大佬  要这么 降级   会吗   小爱版本太高  好难唤醒   先搞回去老版本
 楼主| 发表于 2022-6-1 08:58:49 | 显示全部楼层
怎么降级
发表于 2023-5-10 08:59:17 | 显示全部楼层
用usb接口  update.exe    见 https://github.com/duhow/xiaoai-patch先修改
update.exe bulkcmd "setenv bootdelay 30"
update.exe bulkcmd "saveenv"
发表于 2024-3-17 20:58:53 | 显示全部楼层
有大神知道怎么样解决putty连接TTL,却不显示数据吗?我这边的连线是正确的,可就是无串口数据输出。
发表于 2024-4-9 20:23:27 | 显示全部楼层
进这个failsafe mode才能格式化
发表于 2024-4-10 09:47:41 | 显示全部楼层
学习看看
GMT+8, 2026-1-15 03:37 , Processed in 1.683592 second(s), 13 queries , MemCached On.
