查看: 8694|回复: 2
[技术探讨] 【求助】Hassio 0.57.2 彩云天气SE报错
发表于 2017-11-8 10:39:46 | 显示全部楼层 |阅读模式
用的L大提供的彩云天气SE版,Ha升级0.57.2后,无法更新,申请的彩云APIkey已确认正确无误,log错误日志如下:
求解决思路?
2017-11-08 10:32:04 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.caiyun_realtime_update_realtime_update failsTraceback (most recent call last):  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state    yield from self.async_device_update()  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 309, in async_device_update    yield from self.hass.async_add_job(self.update)  File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__    yield self  # This tells Task to wait for completion.  File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup    future.result()  File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result    raise self._exception  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run    result = self.fn(*self.args, **self.kwargs)  File "/config/custom_components/sensor/CaiyunweatherSE.py", line 697, in update    realupdate_time = time.localtime(self.data_currently['server_time'])KeyError: 'server_time'
发表于 2017-11-8 23:54:50 来自手机 | 显示全部楼层
在你的环境下npm install async即可,如果有效的话留个言
 楼主| 发表于 2017-11-9 21:35:17 | 显示全部楼层
我使用的hassio 原生没有npm命令的,无法安装async
GMT+8, 2025-10-31 00:16 , Processed in 0.049223 second(s), 8 queries , MemCached On.
