楼主: guitengyue
[已解决] broadlink的switch会无故消失?
发表于 2018-3-28 12:59:13 | 显示全部楼层
debitus 发表于 2018-3-28 11:02
当时我配置这些代码页的时候,Ultraedit总把文档保存错误,尾部会多出来一些乱码。
你留意一下文档尾部。 ...
大神。 我刚做了详细的侧测试,命令超过1000字符,启动就报这个错:
03-28 12:56:17 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py", line 158, in setup_platform
    device_config.get(CONF_COMMAND_OFF)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/broadlink.py", line 193, in __init__
    self._command_on = b64decode(command_on) if command_on else None
  File "/usr/lib/python3.6/base64.py", line 87, in b64decode
    return binascii.a2b_base64(s)
发表于 2018-5-6 22:55:19 | 显示全部楼层
问题解决了没
发表于 2019-6-16 14:35:27 来自手机 | 显示全部楼层
问题解决了没?
 楼主| 发表于 2019-6-20 14:40:36 | 显示全部楼层
withome 发表于 2019-6-16 14:35
问题解决了没?
后来没在用这个了。。。。
GMT+8, 2025-12-22 10:19 , Processed in 1.355850 second(s), 13 queries , MemCached On.
