楼主: jva7442
LD-1115H毫米波波雷達DIY人體存在傳感器-成功
 楼主| 发表于 2022-5-29 00:44:16 | 显示全部楼层
御坂御坂 发表于 2022-5-28 19:50
这个可以做好几个然后组一个相控阵吗?
一小顆毫米波雷達可以打到4米(我都嫌訊號太強了,不用那麼靈敏),應該不需要再組相位雷達陣^^
PJK 手机认证
发表于 2022-5-30 08:48:01 | 显示全部楼层
大佬,能不能做个详细的教程呀
发表于 2022-5-30 21:06:02 | 显示全部楼层
楼主能来个详细教程吗,至少贴个ESPHOME代码模访下
 楼主| 发表于 2022-5-31 19:55:45 | 显示全部楼层
binary_sensor:
  - platform: gpio
    pin: <PIN_PIR_SENSOR_IS_CONNECTED_TO>
    device_class: motion
发表于 2022-6-2 02:15:52 | 显示全部楼层
順利被推坑成功!
发表于 2022-6-2 19:34:54 | 显示全部楼层
谢谢大佬分享
发表于 2022-6-13 13:35:23 | 显示全部楼层
https://www.youtube.com/watch?v=VEqWlOeJ2YA
ESPHOME + 串口調試強度
发表于 2022-6-13 14:54:36 | 显示全部楼层
他用的代码,我给各位复制出来了
https://community.home-assistant ... sphome-style/382778
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "password"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "mmWave-Occupancy"
substitutions:
  device_name: mmwave-sensor
captive_portal:
web_server:
  port: 80
  version: 2
  include_internal: true
http_request:
  useragent: esphome/$device_name
  timeout: 2s
switch:
  - platform: safe_mode
    internal: true
binary_sensor:
- platform: gpio
  pin:
    number: GPIO16
    mode: INPUT_PULLDOWN
uart:
  tx_pin: GPIO4
  rx_pin: GPIO5
  baud_rate: 115200
  debug:
    direction: BOTH
    dummy_receiver: true
    after:
      delimiter: "\n"
    sequence:
      - lambda: UARTDebug::log_string(direction, bytes);
number:
  - platform: template
    min_value: 0
    max_value: 1350
    initial_value: 315
    optimistic: true
    step: 15
    restore_value: true
    unit_of_measurement: cm
    set_action:
      - uart.write: "sensorStop"
      - delay: 1s
      - uart.write: !lambda
                      int cm = (int)ceil(x / 15.0);
                      std::string cms = "detRangeCfg -1 0 " + to_string(cm);
                      return std::vector<unsigned char>(cms.begin(), cms.end());
      - delay: 1s
      - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
      - delay: 1s
      - uart.write: "sensorStart"
    min_value: 0
    max_value: 65000
    initial_value: 12500
    optimistic: true
    step: 25
    restore_value: true
    unit_of_measurement: ms
    set_action:
      - delay: 1s
                      int ms = (int)ceil(x / 25.0);
                      std::string mss = "outputLatency -1 0 " + to_string(ms);
                      return std::vector<unsigned char>(mss.begin(), mss.end());
      - delay: 1s
      - delay: 1s
button:
  - platform: restart
    name: Restart $device_name
    on_press:
      - delay: 1s
      - uart.write: "factoryReset 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
      - delay: 3s
发表于 2022-6-17 16:18:40 | 显示全部楼层
sundat 发表于 2022-6-13 14:54
他用的代码,我给各位复制出来了
https://community.home-assistant.io/t/mmwave-presence-de ...
我試用過,但發覺有問題,不會返回 有人跟沒人 的訊號,等其他人試試
发表于 2022-6-17 22:03:15 | 显示全部楼层
厉害了 mark一下
GMT+8, 2025-12-15 06:12 , Processed in 1.310813 second(s), 12 queries , MemCached On.
