查看: 8223|回复: 6
[求助] HA 報錯
发表于 2017-11-7 23:21:02 | 显示全部楼层 |阅读模式
請大神幫忙,出了什麼問題?怎樣解決,謝謝
2017-11-07 23:14:19 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-11-07 23:14:19 WARNING (MainThread) [homeassistant.setup] Setup of camera is taking over 10 seconds.
2017-11-07 23:14:23 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-11-07 23:14:23 WARNING (MainThread) [homeassistant.setup] Setup of fan is taking over 10 seconds.
2017-11-07 23:14:23 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-11-07 23:14:25 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
hugo
发表于 2017-11-8 01:14:29 | 显示全部楼层
这不是严重错误,只是花时间比较长而已,也可能后面初始化好了能正常使用,具体要看详细日志。
 楼主| 发表于 2017-11-8 12:02:46 | 显示全部楼层
hugo 发表于 2017-11-8 01:14
这不是严重错误,只是花时间比较长而已,也可能后面初始化好了能正常使用,具体要看详细日志。 ...
能夠正常使用的,不過想知道為何報錯和如何解決,謝謝師兄回覆!!
发表于 2017-11-8 17:02:12 | 显示全部楼层
不影响使用的,只是警告花的时间较长而已
 楼主| 发表于 2017-11-8 21:35:50 | 显示全部楼层
又有其他報錯,求大神幫忙。。。
2017-11-08 21:31:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
    result = next(coro)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 381, in async_process_entity
    new_entity, self, update_before_add=update_before_add
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 238, in async_add_entity
    yield from entity.async_update_ha_state()
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 246, in async_update_ha_state
    attr = self.state_attributes or {}
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 163, in state_attributes
    self._state_attrs = self.fan_get_prop()
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 379, in fan_get_prop
    prop = self.fan.send("get_prop", ["temp_dec","humidity","angle","speed","poweroff_time","power","ac_power","battery","angle_enable","speed_level","natural_level","child_lock","buzzer","led_b"])
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/miio/miio.py", line 126, in send
    data, addr = s.recvfrom(1024)
socket.timeout: timed out
2017-11-08 21:32:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 331, in async_update_config
    dev_id, device)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 739, in update_config
    with open(path, 'a') as out:
PermissionError: [Errno 13] Permission denied: '/home/homeassistant/.homeassistant/known_devices.yaml'
2017-11-08 21:32:15 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8300: [Errno 99] error while attempting to bind on address ('192.168.0.114', 8300): cannot assign requested address
2017-11-08 21:33:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
    result = next(coro)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1025, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 209, in async_see_service
    yield from tracker.async_see(**args)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 274, in async_see
    dev_id = cv.slug(str(dev_id).lower())
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/config_validation.py", line 236, in slug
    raise vol.Invalid('invalid slug {} (try {})'.format(value, slg))
voluptuous.error.Invalid: invalid slug eric _iphone (try eric__iphone)
发表于 2017-11-8 21:44:29 | 显示全部楼层
只要能正常使用,这些都可以忽略。。
 楼主| 发表于 2017-11-8 22:21:47 | 显示全部楼层
Al_Fred 发表于 2017-11-8 21:44
只要能正常使用,这些都可以忽略。。
明白, 謝謝!
GMT+8, 2025-12-25 15:48 , Processed in 1.238776 second(s), 6 queries , MemCached On.
