查看: 7074|回复: 7
[已解决] 求助,在Hyper-V安装hassos,卡在网页刚开始,怎么办?
发表于 2022-5-18 22:41:48 | 显示全部楼层 |阅读模式
求助,在Hyper-V安装hassos,卡在网页刚开始,已经卡了一晚上了。。。。。求大佬,怎么办?
点击preparing home assistant 下面的小蓝点后,出现的代码如下:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[14:24:52] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:24:52] INFO: Starting local supervisor watchdog...
22-05-18 14:24:52 INFO (MainThread) [__main__] Initializing Supervisor setup
22-05-18 14:24:52 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-05-18 22:24:52 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-05-18 22:24:52 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2022.05.2
22-05-18 22:24:52 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-05-18 22:24:53 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2022.05.1']
22-05-18 22:24:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-05-18 22:24:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-05-18 22:24:53 INFO (MainThread) [__main__] Setting up Supervisor
22-05-18 22:24:55 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-05-18 22:24:55 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-05-18 22:24:55 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-05-18 22:24:55 INFO (MainThread) [supervisor.host.info] Updating local host information
22-05-18 22:24:55 INFO (MainThread) [supervisor.host.services] Updating service information
22-05-18 22:24:55 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-05-18 22:24:55 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-05-18 22:24:55 INFO (MainThread) [supervisor.host.network] Updating local network information
22-05-18 22:24:56 INFO (MainThread) [supervisor.host.network] Updating local network information
22-05-18 22:24:57 INFO (MainThread) [supervisor.host.network] Updating local network information
22-05-18 22:24:58 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-05-18 22:24:58 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.05.0
22-05-18 22:24:58 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-05-18 22:24:59 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-05-18 22:24:59 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.05.0
22-05-18 22:24:59 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-05-18 22:24:59 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-05-18 22:24:59 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-05-18 22:25:03 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-05-18 22:25:03 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
22-05-18 22:25:03 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-05-18 22:25:03 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.0 / BootSlot A
22-05-18 22:25:03 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-05-18 22:25:03 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-05-18 22:25:03 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-05-18 22:25:03 INFO (MainThread) [supervisor.store] Loading add-ons from store: 65 all - 65 new - 0 remove
22-05-18 22:25:03 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-05-18 22:25:03 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-05-18 22:25:03 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-05-18 22:25:03 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-05-18 22:25:03 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-05-18 22:25:03 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-05-18 22:25:03 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-05-18 22:25:03 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-05-18 22:25:03 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-05-18 22:25:03 INFO (MainThread) [__main__] Running Supervisor
22-05-18 22:25:03 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-05-18 22:25:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-05-18 22:25:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-05-18 22:25:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-05-18 22:25:03 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-05-18 22:25:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-05-18 22:25:04 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-05-18 22:25:04 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-05-18 22:25:04 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-05-18 22:25:04 INFO (MainThread) [supervisor.host.info] Updating local host information
22-05-18 22:25:04 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-05-18 22:25:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-05-18 22:25:04 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2022.5.4
22-05-18 22:25:04 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2022.5.4.
22-05-18 22:25:04 INFO (MainThread) [supervisor.host.services] Updating service information
22-05-18 22:25:04 INFO (MainThread) [supervisor.host.network] Updating local network information
22-05-18 22:25:04 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-05-18 22:25:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-05-18 22:25:14 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-05-18 22:25:14 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-05-18 22:25:14 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
虚拟机也配置了外部网卡,难道是磁盘空间?
发表于 2022-5-19 09:00:20 | 显示全部楼层
断电重启,上全局梯子试试
发表于 2022-5-19 10:51:12 | 显示全部楼层
第一次加载会下载UI前端的一些资源,网络也会有影响
发表于 2022-5-19 12:55:46 | 显示全部楼层
没梯子就晚上挂着,第二天早上肯定好了
 楼主| 发表于 2022-5-19 13:26:45 | 显示全部楼层
hanlin 发表于 2022-5-19 12:55
没梯子就晚上挂着,第二天早上肯定好了
挂了一晚上,已经好了,此贴终
发表于 2022-5-19 19:59:01 | 显示全部楼层
虽然已经晚了但我还是要回复一下
这玩意儿就是会卡很久,开全局梯子也还是很久
我几次重装都是这样,往往是睡一觉起来就好了
发表于 2023-4-8 18:13:09 | 显示全部楼层
萌新也卡再这里,继续挂通宵了
发表于 2024-7-20 21:43:08 | 显示全部楼层
刚遇到这问题,挂了一下午没进度,已尝试全局梯子
GMT+8, 2025-12-16 19:54 , Processed in 0.888860 second(s), 16 queries , MemCached On.
