查看: 2618|回复: 4
[求助] 请大佬们帮忙测试下这个esphome风扇代码是哪里出错了
发表于 2022-5-11 08:08:07 | 显示全部楼层 |阅读模式
请大佬们帮忙测试下这个风扇代码是哪里出错了,保留风扇的机械开关。HA内控制继电器没问题,风扇能换档。物理开关只能在断电后控制一次继电器换档,之后binary_sensor  的状态会一直保持 启动,物理开关就会失效无法控制。
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "7972b2158b53edab7f6528"
wifi:
  ssid: "tp6236"
  password: "95698263"
  ap:
    ssid: "d1_mini Fallback Hotspot"
    password: "kfnJHYTxQuQL"
captive_portal:
binary_sensor:
  - platform: gpio
    pin:
      number: 12
      inverted: true
    name: "Fan Local Control Speed 1"
    icon: "mdi:fan-speed-1"
    filters:
      - delayed_on: 500ms
      - delayed_off: 500ms
    on_press:
     then:
      - switch.turn_on: speed1
    on_release:
     then:
      - switch.turn_off: speed1
  - platform: gpio
    pin:
      number: 13
      inverted: true
    name: "Fan Local Control Speed 2"
    icon: "mdi:fan-speed-2"
    filters:
      - delayed_on: 500ms
    on_press:
     then:
      - switch.turn_on: speed2
    on_release:
     then:
      - switch.turn_off: speed2
  - platform: gpio
    pin:
      number: 14
      inverted: true
    name: "Fan Local Control Speed 3"
    icon: "mdi:fan-speed-3"
    filters:
      - delayed_on: 500ms
    on_press:
     then:
      - switch.turn_on: speed3
    on_release:
     then:
      - switch.turn_off: speed3
switch:
 - platform: gpio
   pin: 16
   interlock: &interlock_group [speed1, speed2, speed3]
   interlock_wait_time: 1000ms
   name: "Fan Speed 1"
   inverted: true
 - platform: gpio
   pin: 5
   interlock: *interlock_group
   name: "Fan Speed 2"
   inverted: true
 - platform: gpio
   pin: 4
   name: "Fan Speed 3"
   inverted: true
发表于 2022-5-11 10:34:07 | 显示全部楼层
修改如下,看有没改善(其他照改)?
binary_sensor:
  - platform: gpio
    pin:
      number: 12
      inverted: true
    filters:
      - delayed_on: 500ms
    on_press:
     then:
       - if:
            condition:
              switch.is_off: speed1
            then:
    on_release:
      then:
       - if:
            condition:
              switch.is_on: speed1
            then:
 楼主| 发表于 2022-5-11 22:22:25 | 显示全部楼层
wsbfree 发表于 2022-5-11 10:34
修改如下,看有没改善(其他照改)?
binary_sensor:
  - platform: gpio
你好,按你这个修改后也是一样只有在断电后才能控制一次。二元传感器也是一直保持 开启 这个状态。要断电后才显示关闭。
发表于 2022-5-11 22:45:34 | 显示全部楼层
应该不会的,接线应该没问题?
我用的是esp8266,一般我没用#16 ,其实还有很多口可以用比如#1.#3. ..#15也可以
程序基本没问题。
试下修改类型后重新编译:
esphome:
  platform: ESP8266
  board: esp01_1m
 楼主| 发表于 2022-5-11 23:13:09 | 显示全部楼层
wsbfree 发表于 2022-5-11 22:45
应该不会的,接线应该没问题?
我用的是esp8266,一般我没用#16 ,其实还有很多口可以用比如#1.#3. ..#15也 ...
谢谢,改了 #1 #3  有效了,#15无效。再试试不同的脚。太感谢你了
GMT+8, 2025-12-21 19:27 , Processed in 0.052171 second(s), 7 queries , MemCached On.
