查看: 14081|回复: 10
[技术探讨] hb 发现不了RM PRO设备 没法学习 有没有大神指点一下哈
发表于 2017-11-2 10:05:51 | 显示全部楼层 |阅读模式
HA可以学习 但是hb始终发现不了rm pro设备 ios上点learn rm学习灯不亮 本人小白刚刚学 实在没办法啦 发帖求助一下 各位朋友帮忙指点一下哈
[2017-11-2 10:00:16] [Broadlink RM] Send data (no devices found) 1OCD8]E5XFJXF__C4[IT5%J.png
  "bridge": {
    "name": "Home Assistant",
    "username": "B8:27:EB:F2:10:3A",
    "port": 51826,
    "pin": "123-45-678"
  "accessories": [],
  "platforms": [
      "platform": "HomeAssistant",
      "name": "HomeAssistant",
      "host": "http://192.168.50.125:8123",
      "password": "",
      "default_visibility": "visible",
      "supported_types": [
        "automation",
        "binary_sensor",
        "climate",
        "cover",
        "device_tracker",
        "fan",
        "group",
        "input_boolean",
        "light",
        "lock",
        "media_player",
        "remote",
        "scene",
        "script",
        "sensor",
        "switch",
        "vacuum"
      "logging": true,
      "verify_ssl": true
      "platform":"BroadlinkRM",
      "name":"Broadlink RM",
      "accessories":[
          "name":"风扇",
                  "host":"192.168.50.115",
          "type":"switch",
          "data":{
            "on":"26006c000e00070d0001399a133b151412161613151215131414161215131638133b153a153a1639153b16381539143c14121712133c170f1711141613121614143a15391711143b1539133c1738133b15141413143a17101812161214151412143c133a1414143b143b113d16000d05000000000000000000000000",
            "off":"26006c000e00070d0001399a133b151412161613151215131414161215131638133b153a153a1639153b16381539143c14121712133c170f1711141613121614143a15391711143b1539133c1738133b15141413143a17101812161214151412143c133a1414143b143b113d16000d05000000000000000000000000"
发表于 2017-11-2 14:56:51 | 显示全部楼层
和你遇到同样的问题: [Broadlink RM] Send data (no devices found)  目前我也没找到合适的解决方法.期待大牛的出现.
个人认为是homebridge-broadlink-rm对rm pro的支持上有问题,也在时刻关注着这个问题.
发表于 2017-11-2 15:30:38 | 显示全部楼层
链接到HA就足够了 为什么要再连HB呢?
发表于 2017-11-2 16:14:07 | 显示全部楼层
在HA中设置好,如果要在HB中显示,定义好customize.yaml就行了
 楼主| 发表于 2017-11-2 17:56:19 | 显示全部楼层
Jarvis 发表于 2017-11-2 14:56
和你遇到同样的问题:  Send data (no devices found)  目前我也没找到合适的解决方法.期待大牛的出现.
个人 ...
是啊 ,我在淘宝上花钱,不知道能不能搞,老说还没有时间
 楼主| 发表于 2017-11-2 18:14:12 | 显示全部楼层
哪得学习一下啦
 楼主| 发表于 2017-11-2 18:20:35 | 显示全部楼层
刚开始觉得hb在iOS有学习按键不要在以为学习简单 现在想想一样麻烦
发表于 2017-11-2 21:04:03 | 显示全部楼层
持续关注
发表于 2017-11-3 09:10:27 | 显示全部楼层
全改成接入HA后,以后都不用homebridge每次添加都更新了 加入HA的在HB中就都有了
发表于 2017-11-3 16:32:48 | 显示全部楼层
61741514 发表于 2017-11-3 09:10
全改成接入HA后,以后都不用homebridge每次添加都更新了 加入HA的在HB中就都有了 ...
原来是我刚买的rmpro不支持,可能官方微改啦,等插座更新啦
GMT+8, 2025-10-31 00:15 , Processed in 0.059482 second(s), 10 queries , MemCached On.
