查看: 6810|回复: 3
[求助] 为什么加入博联万能遥控器就无法启动hass了
发表于 2017-11-2 00:26:53 来自手机 | 显示全部楼层 |阅读模式
帮我看下配置哪里错了,删掉博联字段就可以启动(以下)
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 29.1068
  longitude: 119.6442
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
group: !include groups.yaml
script: !include scripts.yaml
xiaomi_aqara:
  gateways:
      - mac: 34:CE:00:90:9A:0D
        key: wijxlmluvtdx5fw1
switch:
  - platform: broadlink
    host: 192.168.31.155
    mac: 34:EA:34:42:E2:80
    timeout: 15
    switches:
      # Will work on most Phillips TVs:
      tv_phillips:
        friendly_name: kitchenroom fans
        command_on:
        command_off:
发表于 2017-11-2 01:19:53 | 显示全部楼层
你直接贴Log信息比较好
发表于 2017-11-5 22:00:34 来自手机 | 显示全部楼层
你的mac地址要加上单引号
发表于 2017-12-12 22:11:43 | 显示全部楼层
我也是在弄博联,反复好几次也是进不去hass,路由器能看到树莓派联网了,又是反复拔插电源,有时候要把博联的删掉,才能进去。
博联在services里能看到,也能录码,但就是看不到博联添加的设备,网上hassio的内容太少了
GMT+8, 2025-12-16 02:03 , Processed in 1.001420 second(s), 12 queries , MemCached On.
