楼主: ryanh7
[插件集成]
发表于 2022-4-25 09:52:28 | 显示全部楼层
感谢大佬
发表于 2022-7-4 22:49:33 | 显示全部楼层
第二张图,查看状态,是在哪里呢?一直没找到位置
发表于 2022-8-8 00:06:35 | 显示全部楼层
萌新同问,最后一个图片“信息”的那个页面找不到在哪?
版本信息:
Home Assistant 2022.8.1
前端版本: 20220802.0 - latest
现在设置了代理,但是依然无法访问,home-assistant.log日志报错
2022-08-08 00:21:26.468 WARNING (MainThread) [custom_components.hacs] A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/thomasloven/lovelace-auto-entities/1.11.0/auto-entities.js, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 0
2022-08-08 00:21:28.472 ERROR (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-auto-entities> [rollup.config.js] was not downloaded.
2022-08-08 00:21:28.590 ERROR (MainThread) [custom_components.hacs] <Plugin thomasloven/lovelace-auto-entities> [auto-entities.js] was not downloaded.
2022-08-08 00:21:28.593 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140474194479328] Error handling message: Unknown error (unknown_error)
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
    await func(hass, connection, msg)
  File "/config/custom_components/hacs/websocket/repository.py", line 212, in hacs_repository_download
    await repository.async_install()
  File "/config/custom_components/hacs/repositories/base.py", line 836, in async_install
    await self.async_install_repository()
  File "/config/custom_components/hacs/repositories/base.py", line 932, in async_install_repository
    raise HacsException("Could not download, see log for details")
custom_components.hacs.exceptions.HacsException: Could not download, see log for details
发表于 2022-8-21 14:52:15 | 显示全部楼层
请问里面那个json文件不需要下载把
发表于 2022-11-2 23:24:11 | 显示全部楼层
yuyuye 发表于 2022-4-19 10:36
试用了非常方便。完美实现了单独代理hacs的愿望
请教下,梯子在旁路由如何设置代理呢?
发表于 2022-11-4 15:50:17 | 显示全部楼层
没梯子 哎
发表于 2022-12-3 22:03:50 | 显示全部楼层
有梯子怎么设置代理
keib
发表于 2023-2-5 22:54:46 | 显示全部楼层
太厉害了!
发表于 2023-4-6 21:43:30 | 显示全部楼层
赞一个,解决大问题
知识,与你分享
发表于 2023-4-12 15:31:47 | 显示全部楼层
好像失效了?
GMT+8, 2026-1-14 20:26 , Processed in 1.127244 second(s), 11 queries , MemCached On.
