查看: 2870|回复: 2
[求助] 安装好homeassistant后用hass启动到最后出示0.0.0.0:8123是怎么回事
发表于 2022-4-16 06:25:08 | 显示全部楼层 |阅读模式
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Requirements for frontend not found: ['home-assistant-frontend==20191204.1'].
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend, recorder
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2022-04-15 23:02:22 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 109.3 seconds.
2022-04-15 23:02:22 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2022-04-15 23:02:22 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.0 seconds.
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud, frontend, history, logbook, map, mobile_app
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2022-04-15 23:02:22 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 343.81s
2022-04-15 23:02:22 WARNING (MainThread) [homeassistant.bootstrap] Python 3.6 support is deprecated and will be removed in the first release after December 15, 2019. Please upgrade Python to 3.7.0 or higher.
2022-04-15 23:02:22 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2022-04-15 23:02:22 INFO (SyncWorker_2) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2022-04-15 23:02:22 INFO (MainThread) [homeassistant.core] Timer:starting
2022-04-15 23:02:22 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address already in use
2022-04-15 23:58:42 INFO (MainThread) [homeassistant.components.updater] Submitted analytics to Home Assistant servers. Information submitted includes {}
2022-04-15 23:58:42 INFO (MainThread) [homeassistant.components.updater] The latest available version of Home Assistant is 2021.4.6
发表于 2022-4-16 08:38:10 | 显示全部楼层
尝试绑定地址时出错('0.0.0.0',8123):地址已在使用中
本机的 8123 端口被占用了。
智能家居&单板滑雪痴迷爱好者
发表于 2022-4-16 08:43:06 | 显示全部楼层
端口已被占用,大概率是你已经启动了一个ha进程了。
另外,你这个怎么还提示最新版本是一年前的???
你的安装环境和安装方法都没说,但是有提示python版本太低,是早在2019年就不再支持的3.6!
如果技术基础欠缺,建议采用hassos安装方式,或者放弃ha,真心话。
这些错误提示都是很直接、很清晰的,但凡有点基础,应该都可以看出问题所在。楼主显然很欠缺,实话说,HA目前远不够成熟易用,还不适合没有IT/编程基础的人。
GMT+8, 2025-12-21 21:21 , Processed in 1.238658 second(s), 13 queries , MemCached On.
