楼主: manymuch
[进阶教程] 通过localtuya接入涂鸦网关下的 蓝牙/zigbee 子设备
发表于 2023-8-15 00:59:01 | 显示全部楼层
beqikaer 发表于 2023-4-16 12:49
Logger: custom_components.localtuya.config_flow
Source: custom_components/localtuya/pytuya/__init_ ...
同样的错误
2023-08-15 00:55:41.124 ERROR (MainThread) [custom_components.localtuya.pytuya] [ebf...m0e] Failed to get status for cid xxxx:
  File "/usr/local/lib/python3.11/asyncio/tasks.py", line 490, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.11/asyncio/locks.py", line 387, in acquire
    await fut
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
  File "/config/custom_components/localtuya/pytuya/__init__.py", line 684, in detect_available_dps
    status = await self.status(cid)
  File "/config/custom_components/localtuya/pytuya/__init__.py", line 598, in status
    status = await self.exchange(ACTION_STATUS, cid=cid)
  File "/config/custom_components/localtuya/pytuya/__init__.py", line 563, in exchange
    msg = await self.dispatcher.wait_for(seqno)
  File "/config/custom_components/localtuya/pytuya/__init__.py", line 325, in wait_for
    await asyncio.wait_for(self.listeners[seqno].acquire(), timeout=timeout)
  File "/usr/local/lib/python3.11/asyncio/tasks.py", line 492, in wait_for
    raise exceptions.TimeoutError() from exc
TimeoutError
2023-08-15 00:55:41.153 DEBUG (MainThread) [custom_components.localtuya.pytuya] [ebf...m0e] Closing connection
2023-08-15 00:55:41.154 ERROR (MainThread) [custom_components.localtuya.config_flow] Unexpected exception
    return fut.result()
    await fut
  File "/config/custom_components/localtuya/config_flow.py", line 450, in async_step_basic_sub_device_info
    self.dps_strings = await validate_input(self.hass, user_input)
  File "/config/custom_components/localtuya/config_flow.py", line 282, in validate_input
    detected_dps = await interface.detect_available_dps(data[CONF_DEVICE_ID])
TimeoutError
发表于 2023-8-23 11:12:36 | 显示全部楼层
前面测试的是一个zigbee 蓝牙多模网关,拿回来升级了固件,版本为联网模块1.48  zigbee模块2.41
应该是协议升级了,可能3.4了。但是不知道怎么测协议版本,脚本只支持到3.3的协议,然后就添加失败
然后换了一个单zigbee涂鸦网关,联网模块V1.13.2  zigbee模块 V1.0.8
网页端添加自动识别为3.3的协议,可以添加成功,也能识别下面的子设备
发表于 2023-8-23 15:22:45 | 显示全部楼层
应该是协 ...
支持zigbee和ble网关的localtuya集成  支持涂鸦3.4协议
https://bbs.hassbian.com/thread-22505-1-1.html
(出处: 『瀚思彼岸』» 智能家居技术论坛)
发表于 2024-3-28 14:45:11 | 显示全部楼层
一直提示 An unknown error occurred. See log for details.  插件装来装去,也更换了ha的旧版本和简易版本,设备也更换了三个,都是各种各样的问题。device id(cid)试过子设备的uuid、tid等所有的id,也试过网关的id,都是这个提示、
localtuya:
  - host: 192.168.xx.xxx
    device_id: 6c4******hx
    local_key: hP******3Li
    friendly_name: 网关
    protocol_version: "3.3"
    is_gateway: true
求各位大神的教导指正。
发表于 2024-7-16 14:13:08 | 显示全部楼层
mark一下
GMT+8, 2025-12-23 16:23 , Processed in 0.284161 second(s), 14 queries , MemCached On.
