查看: 2717|回复: 6
[技术探讨] esphome接达特求助
发表于 2022-3-26 11:49:44 | 显示全部楼层 |阅读模式
按照这个大佬的帖子接的,https://bbs.hassbian.com/thread-13727-1-1.html
esphome:
  platform: ESP8266
  board: nodemcuv2
external_components:
  - source:
      type: local
      path: /config/dart
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "fc608792f14275b45f05340247004291"
wifi:
  ssid: "wifi"
  password: "wifi666"
  ap:
    ssid: "Dartwsz Fallback Hotspot"
    password: "WtkwMy8t3e51"
uart:
  - id: utt2
    tx_pin: D4
    rx_pin: D7
    baud_rate: 9600
  - platform: dart
    formaldehyde:
    uart_id: utt2
captive_portal:
install编译的时候出现
INFO Reading configuration /config/esphome/dartwsz.yaml...
ERROR Unable to load component sensor:
  File "/opt/esphome/esphome/loader.py", line 163, in _lookup_module
    module = importlib.import_module(f"esphome.components.{domain}")
  File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/dart/sensor.py", line 29, in <module>
    cv.Optional(CONF_FORMALDEHYDE): sensor.sensor_schema(
AttributeError: module 'esphome.components.sensor' has no attribute 'sensor_schema'
Failed config
sensor: [source /config/esphome/dartwsz.yaml:36]
  Component not found: sensor.
  - platform: dart
    formaldehyde:
    uart_id: utt2
发表于 2022-3-26 12:05:06 | 显示全部楼层
插件没生效,需要放到esphome根目录下对应路径
 楼主| 发表于 2022-3-26 12:37:57 | 显示全部楼层
大佬有教程吗,我把他放到
  - source:
      type: local
      path: /config/esphome/dart
这里也不行
3万
发表于 2022-3-26 14:16:55 | 显示全部楼层
看提示需要较老版本的esphome才行,新版esphome改变了不少底层的参数配置。 用2021年的较老版本或者等待更新插件。
 楼主| 发表于 2022-3-26 14:48:30 | 显示全部楼层
dscao 发表于 2022-3-26 14:16
看提示需要较老版本的esphome才行,新版esphome改变了不少底层的参数配置。 用2021年的较老版本或者等待更 ...
唉,好吧
发表于 2022-3-26 18:43:38 来自手机 | 显示全部楼层
可以参考一下我的帖子,当时也是报错,后来修改了一下代码就好了
 楼主| 发表于 2022-3-27 19:30:06 | 显示全部楼层
你那个是ze08吧
GMT+8, 2026-1-19 13:21 , Processed in 0.562748 second(s), 10 queries , MemCached On.
