查看: 11321|回复: 6
2.1.0版本homebridge下broadlink rm插件报错
发表于 2017-10-28 15:46:26 | 显示全部楼层 |阅读模式
前两天手贱,升级了 hass.io下homebridge插件到了 2.1.0版本, 然后发现手机没法连上设备了,进去一看,发现homebridge自动停止了,错误信息如下:
[2017-10-28 15:09:20] [HomeAssistant] Received event: pingcrypto.js:181  var ret = this._handle.final();
^Error: error:0606508A:digital envelope routines:EVP_DecryptFinal_ex:data not multiple of block length
at Decipheriv.final (crypto.js:181:26)
at Socket.cs.on (/usr/lib/node_modules/homebridge-broadlink-rm/node_modules/broadlinkjs-rm/index.js:179:27)
at emitTwo (events.js:125:13)
at Socket.emit (events.js:213:7)
at UDP.onMessage [as onmessage] (dgram.js:659:8)/usr/bin/run.sh exited 1[cont-finish.d] executing container finish scripts...[cont-finish.d] done.[s6-finish] syncing disks.[s6-finish] sending all processes the TERM signal.Got SIGHUP, reloading.
No service file found in /etc/avahi/services.write() failed:
Broken pipeFailed to open /etc/resolv.conf: Broken pipeGot SIGTERM, quitting.Leaving mDNS multicast group on interface hassio.IPv6 with address fe80::42:33ff:fe9d:1277.
Leaving mDNS multicast group on interface hassio.IPv4 with address 172.30.32.1.Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::fe4c:2346:e8:6f20.Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.2.114.avahi-daemon 0.6.32 exiting.dbus[736]: [system]
Reloaded configuration[s6-finish] sending all processes the KILL signal and exiting.
好像是broadlink rm插件的问题,重启后3-4小时又会报错,不知道有大神知道是怎么回事吗?如何解决?
hass.io下我的Homebridge配置如下:
{  "log_level": "info",  "avahi_interfaces": "",  "avahi_hostname": "hassio",  "avahi_domainname": "local",  "enable_ipv6": true,  "packages": [],  "init_commands": [],  "plugins": [    "homebridge-broadlink-rm",    "homebridge-broadlink-s1c"  ]}
发表于 2017-10-30 11:06:25 来自手机 | 显示全部楼层
我也是这个问题,我重新装了,用ipad,发现根本就找不到设备了。不知道怎么装回久版本。
 楼主| 发表于 2017-10-31 09:17:19 | 显示全部楼层
lcshine 发表于 2017-10-30 11:06
我也是这个问题,我重新装了,用ipad,发现根本就找不到设备了。不知道怎么装回久版本。 ...
你删除iPad上的桥,重新添加吧...
我发现应该是homebridge-broadlink-s1c这个插件的问题,我删除了,然后更新了Json文件,现在运行2了,没什么问题。。。
不过我的博联S1管家废了。。。
发表于 2017-10-31 23:41:33 | 显示全部楼层
KyleP 发表于 2017-10-31 09:17
你删除iPad上的桥,重新添加吧...
我发现应该是homebridge-broadlink-s1c这个插件的问题,我删除了,然后 ...
好的,我试试看。
发表于 2017-11-1 15:09:12 | 显示全部楼层
有新版本了,在更新试试看~
 楼主| 发表于 2017-11-6 09:19:35 | 显示全部楼层
八哥 发表于 2017-11-1 19:31
是homebridge-broadlink-s1c这个插件安装不上
是的,我删了,然后现在好了...s1c这个插件估计需要更新才行。。。
我就是六神
活跃会员教程狂人灌水之王
发表于 2017-12-8 23:54:40 | 显示全部楼层
2.2.0版本有安装的了吗~~~
GMT+8, 2026-1-10 13:27 , Processed in 0.286715 second(s), 8 queries , MemCached On.
