查看: 19740|回复: 16
[已解决] HASS树莓的GPIO配置文件
发表于 2017-10-27 12:16:35 | 显示全部楼层 |阅读模式
事情搞掂了,我的系统是raspbian系统安装的HASS,导致不行,后面用了HASSBIAN就可以了。
参考了官方说明与群好友Freddy的配置,但还是不行,求高人指点。
#开关2,树莓GPIO
switch 2:
  - platform: rpi_gpio
    ports:
      17: Fan
      invert_logic: False
#switch 2:
 楼主| 发表于 2017-10-27 12:20:22 | 显示全部楼层
invalid config changed to The following components and platforms could not be set up: * [switch.rpi-gpio](https://home-assistant.io/components/switch.rpi_gpio/) * sensor.systemmonitor Please check your config
发表于 2017-10-27 15:44:01 | 显示全部楼层
应该把你的错误日志发上来,而不只是出错提示。
 楼主| 发表于 2017-10-27 18:49:00 | 显示全部楼层
谢谢指点
wqqs 手机认证
活跃会员
发表于 2017-10-27 21:46:13 | 显示全部楼层
invert_logic: False缩进减小两格与port对齐
 楼主| 发表于 2017-10-27 21:55:49 | 显示全部楼层
对了,新的貌似说我没装GPIO
2017-10-27 21:54:34 ERROR (Thread-8) [homeassistant.util.package] Unable to install package RPi.GPIO==0.6.1: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-zq0ki3ds/RPi.GPIO/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-sjs4kgyz-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.4/RPi.GPIO" failed with error code 1 in /tmp/pip-build-zq0ki3ds/RPi.GPIO/
wqqs 手机认证
活跃会员
发表于 2017-10-27 22:04:55 | 显示全部楼层
dgmax 发表于 2017-10-27 21:55
对了,新的貌似说我没装GPIO
2017-10-27 21:54:34 ERROR (Thread-8) [homeassistant.util.package] Unab ...
好像是相关的依赖软件没安装成功
 楼主| 发表于 2017-10-27 22:16:10 | 显示全部楼层
把树莓的PRi.GPIO 改0.6.1了,还是一样提示
pi@raspberrypi:/soft $ sudo pip3 install RPi.GPIO==0.6.1
Collecting RPi.GPIO==0.6.1
  Downloading RPi.GPIO-0.6.1.tar.gz
Building wheels for collected packages: RPi.GPIO
  Running setup.py bdist_wheel for RPi.GPIO ... done
  Stored in directory: /root/.cache/pip/wheels/37/ea/29/ad609e8cc4006f394334b4cf039f314d142a0dd50ce1700ecd
Successfully built RPi.GPIO
Installing collected packages: RPi.GPIO
  Found existing installation: RPi.GPIO 0.6.3
    DEPRECATION: Uninstalling a distutils installed project (RPi.GPIO) has been deprecated and will be removed in a future version. This is due to the fact that uninstalling a distutils project will only partially uninstall the project.
    Uninstalling RPi.GPIO-0.6.3:
      Successfully uninstalled RPi.GPIO-0.6.3
Successfully installed RPi.GPIO-0.6.1
日志如下
论坛风云人物
发表于 2017-10-27 22:23:59 | 显示全部楼层
你只是在原系统下装了新版本,要进入 HA 虚拟环境装才生效。
 楼主| 发表于 2017-10-27 22:40:02 来自手机 | 显示全部楼层
才知道,还有ha虚拟环境,具体是如何进入呢~
GMT+8, 2025-12-24 21:34 , Processed in 1.739943 second(s), 13 queries , MemCached On.
