查看: 1901|回复: 1
[求助] homeassistant用着用着突然崩了
发表于 2022-3-19 19:15:53 | 显示全部楼层 |阅读模式
现在8123端口报404错误
错误如下
2022-03-19 18:16:19 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration google_translate_cn which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-19 18:16:19 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pulseaudio which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-19 18:16:26 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 379, in preload_stream
    stream = await camera.async_create_stream()
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 536, in async_create_stream
    self.stream = create_stream(
  File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 85, in create_stream
    raise HomeAssistantError("Stream integration is not set up.")
homeassistant.exceptions.HomeAssistantError: Stream integration is not set up.
发表于 2022-3-20 00:41:09 来自手机 | 显示全部楼层
重装试试
GMT+8, 2025-12-21 23:49 , Processed in 0.095263 second(s), 7 queries , MemCached On.
