查看: 1724|回复: 4
[经验分享] 脚本不起作用,贴上报错日志,麻烦坛友帮忙看看
发表于 2022-3-9 13:10:22 | 显示全部楼层 |阅读模式
Logger: homeassistant
Source: core.py:1583
First occurred: 12:48:29 (1 occurrences)
Last logged: 12:48:29
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 412, in _async_run
    return await self.script.async_run(script_vars, context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1243, in async_run
    await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 349, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 367, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 749, in _async_choose_step
    await self._async_run_script(script)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 826, in _async_run_script
    await self._async_run_long_action(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 534, in _async_run_long_action
    long_task.result()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 570, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1583, in async_call
    raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service notify.telegram
homeassistant:
  customize:
    sensor.humidifier_turn_off_timer_value:
      icon: mdi:clock
    sensor.humidifier_timers_stop_hours:
      icon: mdi:timer
    script.turn_off_humidifier_time:
      icon: mdi:timer-sand
      friendly_name: "Active Timer Humidifier Turn Off"
fan:
  - platform: xiaomi_miio_airpurifier
    name: Xiaomi Air Humidifier
    host: 192.168.10.59 #ip dell'umidificatore
    token: aade7c87c48cfce3b406a957341ad370
    model: zhimi.humidifier.ca4
input_select:
  humidifier_fan_speed_select:
    options:
      - Auto
      - Low
      - Mid
      - High
    icon: mdi:fan-plus
input_number:
  airhumidifier_target_humidity:
    min: 30
    max: 80
    step: 1
  humidifier_work_time:
    name: Start for minutes
    icon: mdi:timer-outline
    initial: 30
    min: 0
    max: 300
    step: 30
    mode: slider
switch:
  - platform: template
    switches:
      xiaomi_airpurifier_child_lock:
        friendly_name: "Child lock"
        value_template: "{{ is_state_attr('fan.xiaomi_air_humidifier', 'child_lock', True) }}"
        turn_on:
          service: xiaomi_miio_airpurifier.fan_set_child_lock_on
          data:
            entity_id: fan.xiaomi_air_humidifier
        turn_off:
          service: xiaomi_miio_airpurifier.fan_set_child_lock_off
          data:
        icon_template: "mdi:lock-outline"
      xiaomi_airpurifier_buzzer:
        friendly_name: "Buzzer"
        value_template: "{{ is_state_attr('fan.xiaomi_air_humidifier', 'buzzer', True) }}"
        turn_on:
          service: xiaomi_miio_airpurifier.fan_set_buzzer_on
          data:
        turn_off:
          service: xiaomi_miio_airpurifier.fan_set_buzzer_off
          data:
        icon_template: "mdi:volume-off"
      xiaomi_airpurifier_led_high:
        friendly_name: "LED High"
        value_template: "{{ is_state_attr('fan.xiaomi_air_humidifier','led_brightness',2) }}"
        turn_on:
          service: xiaomi_miio_airpurifier.fan_set_led_brightness
          data:
            brightness: 2
        turn_off:
          data:
            brightness: 0
        icon_template: "mdi:lightbulb-on"
      xiaomi_airpurifier_led_mid:
        friendly_name: "LED Mid"
        value_template: "{{ is_state_attr('fan.xiaomi_air_humidifier','led_brightness',1) }}"
        turn_on:
          data:
            brightness: 1
        turn_off:
          data:
            brightness: 0
        icon_template: "mdi:lightbulb-on-outline"
      xiaomi_airpurifier_cleanmode:
        friendly_name: "Clean Mode"
        value_template: "{{ is_state_attr('fan.xiaomi_air_humidifier', 'clean_mode', True) }}"
        turn_on:
          - service: homeassistant.turn_on
          - service: xiaomi_miio_airpurifier.fan_set_clean_mode_on
            data:
        turn_off:
          - service: homeassistant.turn_off
          - service: xiaomi_miio_airpurifier.fan_set_clean_mode_off
            data:
        icon_template: "mdi:spray-bottle"
    sensors:
      airhumidifier_temperature:
        friendly_name: 'Air Humidifier Temperature'
        value_template: "{{ state_attr('fan.xiaomi_air_humidifier','temperature')|float(default=0) }}"
        unit_of_measurement: '掳C'
        icon_template: mdi:thermometer-lines
      airhumidifier_humidity:
        friendly_name: 'Air Humidifier Humidity'
        value_template: "{{ state_attr('fan.xiaomi_air_humidifier','humidity')|int }}"
        unit_of_measurement: '%'
        icon_template: mdi:water-percent
        friendly_name: 'Target humidity'
        value_template: "{{ state_attr('fan.xiaomi_air_humidifier','target_humidity')|int }}"
        icon_template: mdi:water-plus-outline
      airhumidifier_time_work:
        friendly_name: 'Air Humidifier Time Work'
        value_template: "{{ ((state_attr('fan.xiaomi_air_humidifier','power_time') /60)/60)|int }}"
        unit_of_measurement: 'hr'
        icon_template: mdi:calendar-clock
      airhumidifier_use_time_work:
        friendly_name: 'Air Humidifier Use Time'
        value_template: "{{ ((state_attr('fan.xiaomi_air_humidifier','use_time') /60)/60)|int }}"
        icon_template: mdi:timetable
      airhumidifier_water_level:
        friendly_name: 'Air Humidifier Water Level'
        value_template: "{{ state_attr('fan.xiaomi_air_humidifier','water_level') | int }}"
        icon_template: mdi:hydraulic-oil-level
      airhumidifier_speed:
        friendly_name: 'Air Humidifier Speed'
        value_template: |
          {% if state_attr('fan.xiaomi_air_humidifier','preset_mode')|trim != 'None' %}
          {{ state_attr('fan.xiaomi_air_humidifier','preset_mode') }}
          {% else %}
            off
          {% endif %}
        icon_template: mdi:fan-chevron-up
        friendly_name: 'Timer Turn Off'
        value_template: >
          {{ (now().strftime("%s") | int + states("input_number.humidifier_work_time")|int(default=0) * 60 ) | timestamp_custom("%H:%M",false)}}
        friendly_name: 'Water Level'
        value_template: >
          {% set level = states('sensor.airhumidifier_water_level')|int %}
          {% if level <= 12.5 %} 1 {% elif level <= 25 %} 2 {% elif level <= 37.5 %} 3 {% elif level <= 50 %} 4
          {% elif level <= 62.5 %} 5 {% elif level <= 75 %} 6 {% elif level <= 87.5 %} 7 {% else %} 8 {% endif %}
      humidifier_vel_level:
        friendly_name: 'Speed Humidifier detect'
        value_template: >
          {% set vel = state_attr('fan.xiaomi_air_humidifier','speed')|trim %}
          {% if vel == '' or vel == 'null' or vel == 'None' %} Spento {% elif vel == 'Auto' %} Auto {% elif vel == 'Mid' %} Mid {% elif vel == 'Low' %} Low
          {% else %} High {% endif %}
        friendly_name: 'Duration Timer'
        value_template: >
          {% set timers = states("input_number.humidifier_work_time")|int(default=0) %}
          {% set minutes = ((states("input_number.humidifier_work_time")|int(default=0) * 60)  | timestamp_custom("%M",false)) |int(default=0) %}
          {% set hours= ((states("input_number.humidifier_work_time")|int(default=0) * 60)  | timestamp_custom("%H",false)) |int(default=0) %}
          {%- if timers  < 60 -%}
            {%- if timers == 1 -%}
            {{ timers }} Minuto
            {% else %}
            {{ timers }} Minuti
            {% endif %}
          {% else %}
            {%- if timers >= 60 and timers < 120 %}
            {{ hours }} ora {% if minutes != 0  %}e {{ minutes }} Min.{% endif %}
            {% else %}
            {{ hours }} ore {% if minutes != 0  %}e {{ minutes }} Min.{% endif %}
            {% endif %}
          {% endif %}
script:
    mode: restart
    sequence:
      - choose:
          - conditions:
            - condition: template
              value_template: "{{ is_state('fan.xiaomi_air_humidifier','on') }}"
            sequence :
              # persistent_notification.create
              - service: notify.telegram
                data:
                  message: >
                    [馃尅] Sono le {{ now().strftime("%H:%M") }} e l'Umidificatore si
                    chiuder脿 tra {{ states("input_number.humidifier_work_time")|int(default=0) }} {% if states("input_number.humidifier_work_time")|int(default=0) > 1 %}Minuti{% else %}Minuto{% endif %}.
                    {{"\n"}}Precisamente alle ore :  {{ (now().strftime("%s") |int(default=0) + states("input_number.humidifier_work_time")|int(default=0) * 60 ) | timestamp_custom("%H:%M",false)}}.
              - delay:
                  minutes: '{{ states("input_number.humidifier_work_time")|int(default=0) }}'
                data:
                  message: >
                    [馃挙] Umidificatore Spento alle ore {{ now().strftime("%H:%M") }} ed 猫 stato acceso per {{states('sensor.humidifier_timers_stop_hours')}}
        default:
          # persistent_notification.create se non avete il servizio notify telegram
            data:
              message: >
                [鈿狅笍] Umidificatore spento, devi prima accenderlo.
automation:
# impostazione umidit脿 desiderata
  - id: 75855824-aa2a-4bdd-b472-f9f3a67d73c8
    alias: Select target humidity by slider
    mode: restart
    trigger:
      platform: state
      entity_id: input_number.airhumidifier_target_humidity
    condition:
      - "{{ states('sensor.airhumidifier_target_humidity')|int(default=0) != 0}}"
    action:
      - service: xiaomi_miio_airpurifier.fan_set_target_humidity
        data:
          humidity: "{{ states('input_number.airhumidifier_target_humidity')|int(default=0) }}"
  - id: 5ddebb3e-c713-4313-a1d9-02ccbafaa628
    alias: Monitor target humidity and update slider
    mode: restart
    trigger:
      platform: state
      entity_id: sensor.airhumidifier_target_humidity
    action:
      service: input_number.set_value
      data:
        value: '{{ state_attr('fan.xiaomi_air_humidifier','target_humidity') }}'
# notifica mancanza acqua
  - id: 01d9e5ee-71c3-4d21-bf10-a2d7cbef7cf3
    alias: Humidifier - Water tank Empty
    initial_state: 'true'
    mode: queued
    trigger:
      - platform: numeric_state
        entity_id: sensor.airhumidifier_water_level
        below: 10
        above: 0
    action:
        data:
          message: >
            [馃挧] L'Acqua nel serbatoio dell'Umidificatore si sta esaurendo. Il livello 猫 del {{ states('sensor.airhumidifier_water_level')}}%.
# selezione velocita umidificatore
  - id: d5ee03e0-5fbd-4c14-bf5b-200a15355d8a
    alias: Humidifier - Velocity Select
    mode: restart
    trigger:
      - platform: state
        entity_id: input_select.humidifier_fan_speed_select
      - platform: state
        entity_id: sensor.airhumidifier_speed
    action:
      - choose:
        - conditions:
              value_template: "{{ trigger.entity_id == 'sensor.airpurifier_vel_level' }}"
          sequence:
            - service: input_select.select_option
              target:
              data:
                option: "{{ states('sensor.airhumidifier_speed') }}"
        - conditions:
              value_template: "{{ trigger.to_state.state == 'Auto' and trigger.entity_id == 'input_select.humidifier_fan_speed_select' }}"
          sequence:
            - service: fan.set_preset_mode
              data:
                preset_mode: auto
        - conditions:
              value_template: "{{ trigger.to_state.state == 'Low' and trigger.entity_id == 'input_select.humidifier_fan_speed_select' }}"
          sequence:
              data:
                preset_mode: low
        - conditions:
              value_template: "{{ trigger.to_state.state == 'Mid' and trigger.entity_id == 'input_select.humidifier_fan_speed_select' }}"
          sequence:
              data:
                preset_mode: mid
        - conditions:
              value_template: "{{ trigger.to_state.state == 'High' and trigger.entity_id == 'input_select.humidifier_fan_speed_select' }}"
          sequence:
              data:
                preset_mode: high
      - choose:
        - conditions:
              value_template: "{{ state_attr('fan.xiaomi_air_humidifier','preset_mode')|trim != 'None' and  trigger.entity_id == 'sensor.airhumidifier_speed' and trigger.from_state.state != 'off' }}"
          sequence:
              data:
                message: >-
                  {% if states('sensor.airhumidifier_water_level')|int < 10 %}
                  [馃挧] Il livello dell'acqua 猫 sotto il 10%
                   La Velocit脿 Umidificatore sar脿 pre impostata in Auto!
                  {% else %}
                  [馃挧] Velocit脿 Umidificatore Impostata su {{ state_attr('fan.xiaomi_air_humidifier','preset_mode')}}
                  {% endif %}
              value_template: "{{ states('input_select.humidifier_fan_speed_select')|trim !=  states('sensor.airhumidifier_speed') }}"
              target:
              data:
发表于 2022-3-9 13:20:48 | 显示全部楼层
 楼主| 发表于 2022-3-9 16:37:17 | 显示全部楼层
好的 感谢N大
发表于 2022-3-10 01:06:21 | 显示全部楼层
请问如何从那么多信息中提取出有效的信息
发表于 2022-3-10 10:24:04 | 显示全部楼层
blindlight 发表于 2022-3-10 01:06
请问如何从那么多信息中提取出有效的信息
大B哥你这就不懂了吧,我这是上少林寺练过的,方丈还说我有前途
GMT+8, 2026-1-19 15:25 , Processed in 1.253724 second(s), 8 queries , MemCached On.
