查看: 2934|回复: 1
[求助] allowlist_external_dirs可以使用的路径
发表于 2022-3-7 19:47:17 | 显示全部楼层 |阅读模式
请问allowlist_external_dirs能指定的路径必须是/config下面的么?
我想指定为backup,结果报错,指定为/config下面的文件夹就正常。
官网也没有对这一项目进行详细说明,就一句话。
 楼主| 发表于 2022-3-7 19:55:27 | 显示全部楼层
错误日志
[281472723897648] The system cannot restart because the configuration is not valid: Not a directory @ data['allowlist_external_dirs'][0]
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 190, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1630, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1667, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 609, in async_handle_core_service
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Not a directory @ data['allowlist_external_dirs'][0]
经过试验,同一个路径下的
  • addons ×
  • backup ×
  • config √
  • media √
  • share √
  • ssl √
有人知道是为啥嘛
GMT+8, 2025-12-25 16:02 , Processed in 0.564623 second(s), 4 queries , MemCached On.
