楼主: hyifan
[技术探讨] 这里有用ESP32+ILI9341显示屏的吗?咨询个问题。
 楼主| 发表于 2024-1-29 10:11:50 | 显示全部楼层
tettr 发表于 2024-1-28 22:43
楼主,能不能分享一下,你之前用  ESPHOME 来做的 代码呢?
不胜感谢。
esphome:
esp32:
  board: nodemcu-32s
  framework:
    type: arduino
    version: recommended
psram:
logger:
  level: DEBUG
  logs:
    component: ERROR
debug:
  update_interval: 5s
ota:
  password: !secret ota_password
#api:
#  encryption:
#    key: !secret api_key
wifi:
  ssid: !secret wifi_ssid
  fast_connect: on
  reboot_timeout: 15min
  ap:
    ssid: $device_name
    password: "!secret ap_password"
  use_address: esp-livingroom-display.gz
web_server:
  port: 80
  auth:
    username: admin
    password: !secret web_password
time:
  - platform: sntp
    timezone: Asia/Shanghai
spi:
  clk_pin: 18
  mosi_pin: 23
  miso_pin: 19
i2c:
  sda: 21
  scl: 22
  scan: true
mqtt:
  broker: !secret mqtt_broker
  username: !secret mqtt_username
  password: !secret mqtt_password
  topic_prefix: esp_livingroom_display
  - platform: sht4x
    temperature:
      unit_of_measurement: "°C"
      accuracy_decimals: 2
    humidity:
      unit_of_measurement: "%"
    address: 0x44
    heater_max_duty: 0.05
    heater_power: High
    heater_time: Long
    update_interval: 60s
  - platform: bmp280
    temperature:
      oversampling: 16x
    pressure:
    address: 0x76
  - platform: bh1750
    name: "bh1750 illuminance"
    address: 0x23
    update_interval: 30s
    on_value:
      then:
        - if:
            condition:
                - lambda: return x <= 30;
            then:
                - light.turn_on:
                    brightness: 40%
        - if:
            condition:
              and:
                - lambda: return x >= 31 ;
                - lambda: return x <= 80;
            then:
                - light.turn_on:
                    brightness: 65%
        - if:
            condition:
                - lambda: return x >= 81;
            then:
                - light.turn_on:
                    brightness: 100%
  - platform: uptime
    filters:
      - lambda: return x / 3600.0;
    unit_of_measurement: "Hours"
  - platform: template
    icon: mdi:cpu-32-bit
    lambda: |-
      return ESP.getCpuFreqMHz();
    unit_of_measurement: "MHz"
    update_interval: 10s
    icon: mdi:memory
    lambda: |-
      return ESP.getFreeHeap();
    filters:
      - multiply: 0.001
    unit_of_measurement: "KB"
  - platform: mqtt_subscribe
    topic: esp_outside/sensor/temperature/state
#    internal: true
    topic: esp_outside/sensor/humidity/state
#    internal: true
    topic: esp_cy_outside/sensor/temperature/state
#    internal: true
    topic: esp_cy_outside/sensor/humidity/state
#    internal: true
    topic: esp_cy_outside/sensor/voltage/state
    unit_of_measurement: "V"
#    internal: true
# MQTT网络传感器
    topic: node_red/network/wan_up
    unit_of_measurement: "Mbit/s"
#    internal: true
    topic: node_red/network/wan_down
#    internal: true
    topic: node_red/network/vpn_up
#    internal: true
    topic: node_red/network/vpn_down
#    internal: true
# MQTT能源传感器
    topic: node_red/energy/current
    unit_of_measurement: "A"
#    internal: true
    topic: node_red/energy/apparent_power
    unit_of_measurement: "VA"
    filters:
      - multiply: 1000
#    internal: true
    topic: node_red/energy/daily_energy
    unit_of_measurement: "kWh"
#    internal: true
    topic: node_red/energy/monthly_energy
#    internal: true
# DS36717 磁盘空间传感器
    topic: node_red/ds3617/total_size
    unit_of_measurement: "T"
#    internal: true
    topic: node_red/ds3617/used_space
    filters:
    - lambda: return id(total_size).state - x;
#    internal: true
# cy网络设备传感器
text_sensor:
    topic: node_red/network/cy_vpn_status
#    internal: true
    filters:
      - map:
        - home -> 已连接
        - not_home -> 离线
    topic: node_red/network/ds211_status
#    internal: true
    filters:
      - map:
        - home -> 在线
        - not_home -> 离线
# DS3617磁盘状态传感器
    topic: node_red/ds3617/raid_status
#    internal: true
    filters:
      - map:
        - normal -> 正常
        - unknow -> 未知
    topic: node_red/ds3617/disk1_status
#    internal: true
    filters:
      - map:
        - normal -> 正常
        - unknow -> 未知
    topic: node_red/ds3617/disk2_status
#    internal: true
    filters:
      - map:
        - normal -> 正常
        - unknow -> 未知
    topic: node_red/ds3617/disk3_status
#    internal: true
    filters:
      - map:
        - normal -> 正常
        - unknow -> 未知
    topic: node_red/ds3617/disk4_status
#    internal: true
    filters:
      - map:
        - normal -> 正常
        - unknow -> 未知
button:
  - platform: restart
# 显示屏部分
color:
  - id: color_red
    hex: FE1010
  - id: color_green
    hex: 30FE10
  - id: color_blue
    hex: 4C70FA
  - id: color_orange
    hex: F89C08
  - id: color_white
    hex: FFFFFF
  - id: color_pink
    hex: F80983
  - id: color_yellow
    hex: FEFF00
  - id: color_lightblue
    hex: 5EEDFA
font:
# 微软雅黑
  - file: 'msyh.ttf'
    glyphs: 传感压伏出入站概况已连接存储服务器容可安流量当宽带功率上下行潮阳磁盘阵列正常未知在离线室内外温湿度网络日月用电瓦实时信息/!"%()+,-_.::°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnopqrstuvwxyz
  - file: 'msyh.ttf'
  - file: 'msyh.ttf'
output:
  - platform: ledc
    pin: 32
light:
  - platform: monochromatic
    output: gpio_32_backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
display:
  - platform: ili9xxx
    model: ili9341
    data_rate: 80MHz
    update_interval: 1000ms
    cs_pin: 14
    dc_pin: 27
    reset_pin: 33
    rotation: 90
    lambda: |-
      it.line(0, 44, 320, 44, id(color_yellow));
      it.line(160, 44, 160, 240, id(color_yellow));
      it.line(0, 135, 320, 135, id(color_yellow));
      static int i = 1;
      i++;
      if ((i % 2) == 0)
        it.printf(160, 10, id(msyh_size_34), id(color_white), TextAlign::CENTER, ":");
      it.strftime(160, 12, id(msyh_size_34), id(color_white), TextAlign::CENTER, "%H %M", id(sntp_time).now());
      it.strftime(160, 35, id(msyh_size_14), id(color_white), TextAlign::CENTER, "%Y-%m-%d", id(sntp_time).now());
      it.printf(310, 3, id(msyh_size_14), id(color_green), TextAlign::RIGHT, "室内温湿度");
      it.printf(320, 24, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f°C/%.1f%%", id(livingroom_temperature).state, id(livingroom_humidity).state);
      it.printf(5, 3, id(msyh_size_14), id(color_green), TextAlign::LEFT, "室外温湿度");
      it.printf(0, 24, id(msyh_size_14), id(color_white), TextAlign::LEFT, "%.1f°C/%.1f%%", id(outside_temperature).state, id(outside_humidity).state);
      it.printf(82, 53, id(msyh_size_14), id(color_green), TextAlign::CENTER, "实时网络概况");
      it.printf(10, 65, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "上行流量:");
      it.printf(155, 65, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f Mb/s", id(wan_up).state);
      it.printf(10, 82, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "下行流量:");
      it.printf(155, 82, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f Mb/s", id(wan_down).state);
      it.printf(10, 99, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "VPN上行:");
      it.printf(155, 99, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f Mb/s", id(vpn_up).state);
      it.printf(10, 116, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "VPN下行:");
      it.printf(155, 116, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f Mb/s", id(vpn_down).state);
      it.printf(240, 53, id(msyh_size_14), id(color_green), TextAlign::CENTER, "实时用电概况");
      it.printf(180, 65, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "实时电流:");
      it.printf(300, 65, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.3f 安", id(current).state);
      it.printf(180, 82, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "实时功率:");
      it.printf(300, 82, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.0f 瓦", id(apparent_power).state);
      it.printf(180, 99, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "日用电量:");
      it.printf(300, 99, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f 度", id(daily_energy).state);
      it.printf(180, 116, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "月用电量:");
      it.printf(300, 116, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.1f 度", id(monthly_energy).state);
      it.printf(82, 145, id(msyh_size_14), id(color_green), TextAlign::CENTER, "存储服务概况");
      it.printf(10, 157, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "容量/可用:");
      it.printf(155, 157, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%.2fT/%.2fT", id(total_size).state, id(free_space).state);
      it.printf(10, 174, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "磁盘阵列:");
      it.printf(155, 174, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%s", id(raid_status).state.c_str());
      it.printf(10, 191, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "磁盘 1/2:");
      it.printf(155, 191, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%s/%s", id(disk1).state.c_str(), id(disk2).state.c_str());
      it.printf(10, 208, id(msyh_size_14), id(color_lightblue), TextAlign::LEFT, "磁盘 3/4:");
      it.printf(155, 208, id(msyh_size_14), id(color_white), TextAlign::RIGHT, "%s/%s", id(disk3).state.c_str(), id(disk4).state.c_str());
参与人数 1金钱 +16 收起 理由
sorrypqa + 16 高手,这是高手!
 楼主| 发表于 2024-1-29 10:16:21 | 显示全部楼层
QQ617250210 发表于 2024-1-29 09:59
提供个思路,我之前也遇到过,不过是花屏,最后原因是杜邦线接触不良导致的,你可以看看你的 ...
这问题早解决了.原因是i2c的线太长了,后来自己做了个PCB,把esp32一起做到显示屏接口板上就再也没出现问题了.
发表于 2024-1-29 11:18:58 | 显示全部楼层
非常感情,楼主的分享。
在学习研究,看看能不能成功。
发表于 2024-5-6 20:41:25 | 显示全部楼层
你好,楼主,请问一下,TFT屏幕,控制底色 显示 白色或黑色 ,怎样编写语句呢
it.fill(COLOR_BLACK);
it.fill (COLOR_WHITE);
是不是这样的呢
发表于 2024-5-9 09:43:55 | 显示全部楼层
是不是这样的呢
yjl 手机认证
发表于 2024-5-9 12:18:01 | 显示全部楼层
好贴,收藏学习了
总为浮云能避日,长安不见使人愁
GMT+8, 2026-1-14 20:53 , Processed in 1.610220 second(s), 11 queries , MemCached On.
