楼主: dscao
[插件集成] 2025.1后使用的修改版havcs自定义组件
发表于 2024-7-2 10:49:29 | 显示全部楼层
222222222222222222222222222222
xara
发表于 2024-7-2 13:05:36 | 显示全部楼层
点击“同步设备”出错:
WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open inside the event loop by custom integration 'havcs' at custom_components/havcs/http.py, line 400: save_yaml(self._hass.data[INTEGRATION][CONF_DEVICE_CONFIG_PATH], self._hass.data[INTEGRATION][DATA_HAVCS_ITEMS]) (offender: /usr/src/homeassistant/homeassistant/util/yaml/dumper.py, line 36: with open(path, "w", encoding="utf-8") as outfile, please report it to the author of the 'havcs' custom integrationTraceback (most recent call last):
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 190, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 672, in run_until_complete
    self.run_forever()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 639, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1988, in _run_once
    handle._run()
  File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/config/custom_components/havcs/http.py", line 400, in post
jpeg
发表于 2024-7-3 11:34:22 | 显示全部楼层
谢谢,看看更新后是不是正常
发表于 2024-7-4 17:07:14 | 显示全部楼层
支持一下
发表于 2024-7-8 00:20:31 | 显示全部楼层
感谢!!!
发表于 2024-7-14 22:10:33 | 显示全部楼层
膜拜大神。
发表于 2024-7-15 13:26:02 | 显示全部楼层
感谢大佬,我正在找这个,但是我好像看不到隐藏内容呢。
发表于 2024-7-27 22:00:31 | 显示全部楼层
好好学习一下
发表于 2024-8-10 09:42:29 | 显示全部楼层
谢谢,需要对接小度。
发表于 2024-8-11 17:11:23 | 显示全部楼层
目前HA版本2024.8.1,HAVCS用的是楼主发的包,菜单栏已经出现HAVCS了,但是在小度技能我不管怎么试都是授权失败,是需要小度技能备案吗?域名备案吗?
GMT+8, 2025-12-17 07:39 , Processed in 0.721299 second(s), 11 queries , MemCached On.
