查看: 3137|回复: 3
[求助] 求助各位大佬 SSH & Web Terminal一直报502
发表于 2022-3-5 21:11:33 | 显示全部楼层 |阅读模式
每次启动一直出现这个错误
SSH & Web Terminal[color=var(--mdc-dialog-content-ink-color, rgba(0, 0, 0, 0.6))]
[color=var(--primary-text-color)]Add-on is not running. Please start it first
[color=var(--primary-text-color)]这是日志
SSH & Web Terminal
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] permissions: applying...
[fix-attrs.d] permissions: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: SSH & Web Terminal
 SSH & Web Terminal access to your Home Assistant instance
 Add-on version: 10.0.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 7.4  (amd64 / qemux86-64)
 Home Assistant Core: 2022.3.1
 Home Assistant Supervisor: 2022.01.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] docker.sh: executing...
[cont-init.d] docker.sh: exited 0.
[cont-init.d] mosquitto.sh: executing...
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] mysql.sh: executing...
[cont-init.d] mysql.sh: exited 0.
[cont-init.d] ssh.sh: executing...
[21:07:50] FATAL:
[21:07:50] FATAL: Configuration of this add-on is incomplete.
[21:07:50] FATAL:
[21:07:50] FATAL: Please be sure to set a least a SSH password
[21:07:50] FATAL: or at least one authorized key!
[21:07:50] FATAL:
[21:07:50] FATAL: You can configure this using the "ssh.password"
[21:07:50] FATAL: or the "ssh.authorized_keys" option in the
[21:07:50] FATAL: add-on configuration.
[21:07:50] FATAL:
[cont-init.d] ssh.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
发表于 2022-3-6 10:24:26 | 显示全部楼层
日志写的很清楚了....
 楼主| 发表于 2022-3-6 10:41:56 | 显示全部楼层
gungda 发表于 2022-3-6 10:24
日志写的很清楚了....
好的 谢谢啦 我昨晚搞定了 第一次搞有点没什么思路
发表于 2024-12-7 01:17:29 | 显示全部楼层
大佬这个是啥问题,刚接触,docker logs addon_fb59d657_ssh报错和你的一摸一样
GMT+8, 2025-12-17 20:55 , Processed in 0.175785 second(s), 14 queries , MemCached On.
