查看: 4203|回复: 4
[技术探讨] 求助PZEM-004电表计算电费模板新的写法
发表于 2022-3-2 22:35:26 | 显示全部楼层 |阅读模式
我用的是PZEM-004刷的tasmota固件。当时按照论坛的教程配置的hass,当时一切正常,通过电费模板可以按照用电量自动核算阶梯电费。
后来hass不断的升级新版本,忘了是升级哪个hass版本后,发现计算电费的的模板始终是按照最高的阶梯电价来计算电费的,而且看了的系统日志,也有这方面的警告提示,但无奈水平有限,不知道怎么解决。寻求坛友帮助
提示错误信息的日志:
WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'float' got invalid input 'unknown' when rendering template '{% if now().month in [1,3,5,7,8,10,12] %} {% set date = (31 - now().day) %} {% elif now().month in [4,6,9,11] %} {% set date = (30 - now().day) %} {% elif now().month == 2 and ((now().year-2000) % 4 > 0) %} {% set date = (28 - now().day) %} {% elif now().month == 2 and ((now().year-2000) % 4 == 0) %} {% set date = (29 - now().day) %} {% endif %} {% if (date != 0 and (states("sensor.dianbiaoelectric") | float - states("sensor.dianbiaojinri_dianliang") | float + (states("sensor.dianbiaozuori_dianliang") | float * (date + 1))) | int > 250) or (date == 0 and states("sensor.dianbiaoelectric") | int > 250) %} {{(states("sensor.dianbiaoelectric") | float * 0.82) | round(2)}} {% elif (date != 0 and (states("sensor.dianbiaoelectric") | float - states("sensor.dianbiaojinri_dianliang") | float + (states("sensor.dianbiaozuori_dianliang") | float * (date + 1))) | int > 170) or (date == 0 and states("sensor.dianbiaoelectric") | int > 170) %} {{(states("sensor.dianbiaoelectric") | float * 0.57) | round(2)}} {% else %} {{(states("sensor.dianbiaoelectric") | float * 0.52) | round(2)}} {% endif %}' but no default was specified. Currently 'float' will return '0', however this template will fail to render in Home Assistant core 2022.1
现在配置的代码:
####电表电量####
  #电压传感器
  - platform: mqtt
    state_topic: "tele/dianliang/SENSOR"
    qos: 1
    unit_of_measurement: "V"
    value_template: "{{ value_json['ENERGY'].Voltage }}"
  #电流传感器
  - platform: mqtt
    qos: 1
    unit_of_measurement: "A"
    value_template: "{{ value_json['ENERGY'].Current }}"
  #功率传感器
  - platform: mqtt
    qos: 1
    unit_of_measurement: "W"
    value_template: "{{ value_json['ENERGY'].Power }}"
  #功率因数传感器
  - platform: mqtt
    qos: 1
    unit_of_measurement: "cosΦ"
    value_template: "{{ value_json['ENERGY'].Factor }}"
  #电表箱温度
  - platform: mqtt
    qos: 1
    unit_of_measurement: "℃"
    value_template: "{{ value_json['AHT1X-0x38'].Temperature }}"
  #电表箱湿度
  - platform: mqtt
    qos: 1
    unit_of_measurement: "%"
    value_template: "{{ value_json['AHT1X-0x38'].Humidity }}"
  #今天用电量
  - platform: mqtt
    qos: 1
    unit_of_measurement: "kWh"
    value_template: "{{ value_json['ENERGY'].Today }}"
  #今日电费
  - platform: template
    sensors:
      dianbiaojinri_dianfei:
        value_template: >
          {% endif %}
          {{(states("sensor.dianbiaojinri_dianliang") | float * 0.82) | round(2)}}
          {{(states("sensor.dianbiaojinri_dianliang") | float * 0.57) | round(2)}}
          {% else %}
          {{(states("sensor.dianbiaojinri_dianliang") | float * 0.52) | round(2)}}
          {% endif %}
        unit_of_measurement: "RMB"
  #昨天用电量
  - platform: mqtt
    qos: 1
    value_template: "{{ value_json['ENERGY'].Yesterday }}"
  #昨日电费
    sensors:
      dianbiaozuori_dianfei:
        value_template: >
          {% endif %}
          {{(states("sensor.dianbiaozuori_dianliang") | float * 0.82) | round(2)}}
          {{(states("sensor.dianbiaozuori_dianliang") | float * 0.57) | round(2)}}
          {% else %}
          {{(states("sensor.dianbiaozuori_dianliang") | float * 0.52) | round(2)}}
          {% endif %}
  #总用电量
  - platform: mqtt
    qos: 1
    value_template: "{{ value_json['ENERGY'].Total }}"
    state_class: 'total'
    device_class: 'energy'
  #总电费
    sensors:
      dianbiaozongdianfei:
        value_template: >
          {% endif %}
          {% else %}
          {% endif %}
3万
发表于 2022-3-3 14:40:01 | 显示全部楼层
现在的“能源”面板不香吗?设置完整了,随便哪天的电费还是哪月的电费都能查呀。
 楼主| 发表于 2022-3-3 19:22:09 | 显示全部楼层
dscao 发表于 2022-3-3 14:40
现在的“能源”面板不香吗?设置完整了,随便哪天的电费还是哪月的电费都能查呀。 ...
是挺香的,我也同时设置着能源面板,但是在能源里无法显示实时功率、电压、电流等信息
发表于 2022-3-6 12:21:01 来自手机 | 显示全部楼层
能源面板怎么设置?大佬有相关教程吗
论坛助手,iPhone
hxin
发表于 2022-3-14 12:55:45 | 显示全部楼层
能源数据怎么显示电费呀?麻烦有空指点下
GMT+8, 2026-1-19 15:25 , Processed in 1.361501 second(s), 13 queries , MemCached On.
