查看: 5435|回复: 6
[技术探讨] 海康摄像头的接入firgate遇到点问题,求教
发表于 2022-3-2 16:10:56 | 显示全部楼层 |阅读模式
之前都好,最近摄像头开始频繁死机,问了客服说需要升级固件,现在升级固件后,参数没动的情况下,firgate里画面就绿了日志:
[2022-03-02 22:45:51] frigate.app INFO : Camera processor started for ezviz: 239
[2022-03-02 22:45:51] frigate.app INFO : Capture process started for ezviz: 241
[2022-03-02 22:45:51] ws4py INFO : Using epoll
[2022-03-02 22:45:54] frigate.video ERROR : ezviz: Unable to read frames from ffmpeg process.
[2022-03-02 22:45:54] frigate.video ERROR : ezviz: ffmpeg process is not running. exiting capture thread...
[2022-03-02 22:46:11] watchdog.ezviz ERROR : Ffmpeg process crashed unexpectedly for ezviz.
[2022-03-02 22:46:11] watchdog.ezviz ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
[2022-03-02 22:46:11] ffmpeg.ezviz.detect ERROR : [rtsp @ 0x5573d85ea940] DTS discontinuity in stream 1: packet 34 with DTS 148160911864743, packet 35 with DTS 148160911875646
[2022-03-02 22:46:11] ffmpeg.ezviz.detect ERROR : [flv @ 0x5573d860df40] FLV does not support sample rate 48000, choose from (44100, 22050, 11025)
[2022-03-02 22:46:11] ffmpeg.ezviz.detect ERROR : [flv @ 0x5573d860df40] Audio codec mp2 not compatible with flv
[2022-03-02 22:46:11] ffmpeg.ezviz.detect ERROR : Could not write header for output file #0 (incorrect codec parameters ?): Function not implemented
自己解决了,原来更新前有ACC音频编码的,更新后没了,为了适配另个安全视频我选了Mp2音频,导致了不兼容
发表于 2022-3-2 17:28:37 | 显示全部楼层
编码使用 264 试试。不要开 smart264
 楼主| 发表于 2022-3-2 17:44:54 | 显示全部楼层
确定是H264编码,smart264也没开
现在直接接入hass是正常的
发表于 2022-3-2 19:47:44 | 显示全部楼层
有试coral tpu ,现在很难买得到,想要usb的
 楼主| 发表于 2022-3-2 22:52:17 | 显示全部楼层
这个不知道该怎么办
发表于 2022-3-3 14:01:51 | 显示全部楼层
这是哪款摄像头?我的frigate搭好了需要采购一批摄像头
发表于 2022-3-9 12:15:45 | 显示全部楼层
你这是wifi摄像头吧,摄像头处理不过来就会报这种错误
GMT+8, 2026-1-19 15:25 , Processed in 1.752032 second(s), 16 queries , MemCached On.
