查看: 2881|回复: 2
[已解决] 修改homekit组件源代码无效
发表于 2022-2-28 12:55:00 | 显示全部楼层 |阅读模式
  各位大佬,小弟这边尝试修改了一下homekit组件的源代码,然后把项目拷贝到了config/custom_components/路径下并且在configuration.yaml中添加了homekit:
  但是重启HA服务后,发现了报错日志:Error occurred loading configuration flow for integration homekit: cannot import name 'ATTR_HW_VERSION' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py)
  请问各位该如何是好?
[backcolor=var(--mdc-theme-surface, #fff)][color=var(--mdc-dialog-content-ink-color, rgba(0, 0, 0, 0.6))]Error occurred loading configuration flow for integration homekit: cannot import name 'ATTR_HW_VERSION' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py)
发表于 2022-2-28 22:43:50 | 显示全部楼层
目的是什么
 楼主| 发表于 2022-3-10 08:17:23 | 显示全部楼层
已经完成了插件的修改和替换,谢谢您的回复
GMT+8, 2025-12-25 15:53 , Processed in 0.930110 second(s), 13 queries , MemCached On.
