查看: 8696|回复: 11
[插件集成] 新手遇到HACS安装配置问题,请教大神
hxin
发表于 2022-2-19 23:02:06 | 显示全部楼层 |阅读模式
HACS算是安装上了,但是无法使用,麻烦大神帮我看看应该怎么配置,
此错误来自自定义集成。
Logger: homeassistant
Source: custom_components/hacs/tasks/setup_frontend.py:11
Integration: HACS (documentation, issues)
First occurred: 22:58:24 (3 occurrences)
Last logged: 22:58:39
Error doing job: Task exception was never retrieved
  File "/config/custom_components/hacs/__init__.py", line 205, in async_reload_entry
    await async_setup_entry(hass, config_entry)
  File "/config/custom_components/hacs/__init__.py", line 168, in async_setup_entry
    return await async_initialize_integration(hass=hass, config_entry=config_entry)
  File "/config/custom_components/hacs/__init__.py", line 104, in async_initialize_integration
    await hacs.tasks.async_load()
  File "/config/custom_components/hacs/tasks/manager.py", line 42, in async_load
    await asyncio.gather(*[_load_module(task) for task in task_modules])
  File "/config/custom_components/hacs/tasks/manager.py", line 38, in _load_module
    task_module = import_module(f"{__package__}.{module}")
  File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
  File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 850, in exec_module
  File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
  File "/config/custom_components/hacs/tasks/setup_frontend.py", line 11, in <module>
    from ..hacs_frontend import locate_dir
ModuleNotFoundError: No module named 'custom_components.hacs.hacs_frontend'
发表于 2022-2-22 10:22:32 | 显示全部楼层
截图右下角三个点,重新下载。
hxin
 楼主| 发表于 2022-2-22 12:10:12 | 显示全部楼层
BlueFang 发表于 2022-2-22 10:22
截图右下角三个点,重新下载。
删除后重新下HACS,重新拷贝新版本至custom_components目录下,重新搜索 安装还是这样的问题,
已经用了最新版本的HACS:https://github.com/hacs/integration/releases/tag/1.23.0
是不是HA的问题呢~
发表于 2022-2-22 13:56:23 | 显示全部楼层
进入控制台安装:
wget -O - https://get.hacs.xyz | bash -
安装后重启hassio或者docker。
hxin
 楼主| 发表于 2022-2-22 21:40:15 | 显示全部楼层
BlueFang 发表于 2022-2-22 13:56
进入控制台安装:
我是在威联通里用“VirtualizationStation 3”安装的hassio,
login
从浏览器输入 :https://get.hacs.xyz
自动跳转至:https://raw.githubusercontent.com/hacs/get/main/get
这会网页打不开,想知道上图操作步骤对吗?我等网可以访问了继续尝试……
发表于 2022-2-23 09:25:23 | 显示全部楼层
官网有说明:https://hacs.xyz/docs/setup/download
不能访问的话,试试这个命令:
wget -O - https://raw.githubusercontent.com/hacs/get/main/get | bash -
hxin
 楼主| 发表于 2022-2-23 09:30:56 | 显示全部楼层
不能访问的话,试试这个命令:
也试过了,谢谢你了,我有空再多试试,
发表于 2022-2-23 23:36:12 | 显示全部楼层
请问有解决吗
hxin
 楼主| 发表于 2022-2-24 00:02:22 | 显示全部楼层
目前 还没有,阶段性重试,有新版下新版继续尝试……
发表于 2022-2-24 16:52:24 | 显示全部楼层
兄弟,已解决。https://bbs.hassbian.com/forum.p ... mp;extra=#pid434197
GMT+8, 2026-1-19 17:22 , Processed in 0.778414 second(s), 8 queries , MemCached On.
