查看: 6017|回复: 7
[技术探讨] caiyun SE版天气在hassio版本更新0.56.1后,启动出现错误信息
发表于 2017-10-23 12:39:47 | 显示全部楼层 |阅读模式
RT错误信息如下:
有人遇到了吗?
2017-10-23 12:31:01 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.caiyun_daily_wind_direction_max failsTraceback (most recent call last):  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state    yield from self.async_device_update()  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 309, in async_device_update    yield from self.hass.async_add_job(self.update)  File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__    yield self  # This tells Task to wait for completion.  File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup    future.result()  File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result    raise self._exception  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run    result = self.fn(*self.args, **self.kwargs)  File "/config/custom_components/sensor/CaiyunweatherSE.py", line 737, in update    forecast_data = json.load(file_data)  File "/usr/lib/python3.6/json/__init__.py", line 299, in load    parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)  File "/usr/lib/python3.6/json/__init__.py", line 354, in loads    return _default_decoder.decode(s)  File "/usr/lib/python3.6/json/decoder.py", line 339, in decode    obj, end = self.raw_decode(s, idx=_w(s, 0).end())  File "/usr/lib/python3.6/json/decoder.py", line 357, in raw_decode    raise JSONDecodeError("Expecting value", s, err.value) from Nonejson.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
发表于 2017-10-23 14:46:31 | 显示全部楼层
还没搞定api key
 楼主| 发表于 2017-10-24 20:30:29 | 显示全部楼层
在彩云天气的网址站申请免费开发者账号就可以了,确认信要求发送实名信息,估计要等待3~5天,我等了一周。
教程狂人论坛风云人物突出贡献
发表于 2017-10-24 22:11:08 来自手机 | 显示全部楼层
json文件读不到
发表于 2017-10-25 12:41:51 | 显示全部楼层
怎么处理呢??
教程狂人论坛风云人物突出贡献
发表于 2017-10-25 12:45:44 | 显示全部楼层
点更新脚本,下载天气json啊
 楼主| 发表于 2017-10-26 22:32:19 | 显示全部楼层
lidicn 发表于 2017-10-25 12:45
点更新脚本,下载天气json啊
json可以读取到的,手动更新是可以,但用automation更新就时常会出现如此错误
教程狂人论坛风云人物突出贡献
发表于 2017-10-26 22:36:00 来自手机 | 显示全部楼层
这应该是,更新的时候删除文件重新下载。的一瞬间读不了文件报错。更新没必要太频繁,一般30分钟,或者15分钟。自动化区有范例。
GMT+8, 2025-9-7 04:56 , Processed in 0.189835 second(s), 8 queries , MemCached On.
