查看: 3087|回复: 4
[求助] Node-red提示502: Bad Gateway 求助!搞两天了
发表于 2022-2-11 18:45:53 | 显示全部楼层 |阅读模式
已经配置设置了账号密码 填入了都不行
certfile: fullchain.pem
credential_secret: qweqwe123qwe
http_node:
  password: sabuidhb
  username: qweqweqwe1qwe
http_static:
  password: homeassistant
  username: homeassi3stant
init_commands: []
keyfile: privkey.pem
npm_packages: []
ssl: false
system_packages: []
theme: default
也已经设置为false
日志也没说具体什么问题  就是访问不上  错误等
发表于 2022-2-11 23:05:05 | 显示全部楼层
require_ssl: true
把这一行加到配置文件底下
发表于 2022-2-15 11:47:57 | 显示全部楼层
配置文件没问题
3万
发表于 2022-2-15 14:02:18 | 显示全部楼层
日志肯定有的,至少nginx那一步没启动或者启动后就崩溃了。
把全部日志帖了来看看呀
- /opt/node_modules/node-red-contrib-modbus/modbus/modbus-flex-sequencer.js
- /opt/node_modules/@node-red/registry/lib/loader.js
- /opt/node_modules/@node-red/registry/lib/index.js
- /opt/node_modules/@node-red/runtime/lib/nodes/index.js
- /opt/node_modules/@node-red/runtime/lib/index.js
- /opt/node_modules/node-red/lib/red.js
- /opt/node_modules/node-red/red.js
15 Feb 14:00:54 - [warn] ------------------------------------------------------
15 Feb 14:00:54 - [info] Settings file  : /etc/node-red/config.js
15 Feb 14:00:54 - [info] Context store  : 'store' [module=localfilesystem]
15 Feb 14:00:54 - [info] Context store  : 'default' [module=memory]
15 Feb 14:00:55 - [info] User directory : /config/node-red/
15 Feb 14:00:55 - [warn] Projects disabled : editorTheme.projects.enabled=false
15 Feb 14:00:55 - [info] Flows file     : /config/node-red/flows.json
15 Feb 14:00:55 - [info] Server now running at http://127.0.0.1:46836/
[14:00:55] INFO: Starting NGinx...
15 Feb 14:00:56 - [info] Starting flows
15 Feb 14:00:59 - [info] Started flows
Starting NGinx.. 完成之前都是 502: Bad Gateway
 楼主| 发表于 2022-2-15 15:20:53 | 显示全部楼层
我现在准备重新安装了 整个设备
GMT+8, 2025-11-6 04:20 , Processed in 0.149330 second(s), 9 queries , MemCached On.
