查看: 5700|回复: 3
[求助] HASS 打开错误SyntaxError: invalid syntax,求帮助
发表于 2017-10-23 11:41:04 | 显示全部楼层 |阅读模式
本人小白一枚 无任何编程基础  求解决
Administrator@lixm MINGW64 ~
$ hass
  File "c:\users\administrator\appdata\local\programs\python\python37\lib\runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "c:\users\administrator\appdata\local\programs\python\python37\lib\runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "C:\Users\Administrator\AppData\Local\Programs\Python\Python37\Scripts\hass.exe\__main__.py", line 5, in <module>
  File "c:\users\administrator\appdata\local\programs\python\python37\lib\site-packages\homeassistant\__main__.py", line 279
    from homeassistant.util.async import run_callback_threadsafe
 楼主| 发表于 2017-10-23 12:15:53 | 显示全部楼层
window7下安装的Python,安装homeassistant 成功  执行hass提示失败
发表于 2017-10-23 12:41:52 | 显示全部楼层
windows装homessistant启动不是这样启动的。。。具体你可以看看这个帖子:
https://bbs.hassbian.com/forum.p ... p;highlight=windows
 楼主| 发表于 2017-10-23 16:37:06 | 显示全部楼层
https://bbs.hassbian.com/foru ...
试过了  打开HASS是最基本的  都打不开
GMT+8, 2025-11-6 04:20 , Processed in 0.100585 second(s), 11 queries , MemCached On.
