查看: 4644|回复: 9
[基础教程] 博联遥控学码后,如何创建实体呀
发表于 2022-2-6 16:09:08 | 显示全部楼层 |阅读模式
小白一个,求大神给说一下子呀
发表于 2022-2-6 16:58:30 | 显示全部楼层
没创建实体,写了一堆script来使用。。
living_room_remote_tvbox_home:
    sequence:
      - service: remote.send_command
        data:
          entity_id: remote.living_room_broadlink
          command: "b64:JgBQAAABKpMUERQRFREUERURFBEUERU1FDYUNhQ1FTUVNRQ2FDYUERQ2FDYUERQRFTUUNhQ2FBEUERURFDUVNRURFBEUERU1FAAFHAABKkkUAA0FAAAAAAAAAAA="
发表于 2022-2-6 16:59:08 | 显示全部楼层
类似于这样,switch.yaml里面写。你没有的话config那个文件写应该也行。另外你这发了几个帖子。。。。相同类似问题建议你还是写一个帖子就好,也可以试着换说法在论坛搜搜看,一般都有类似的解决方法。
#switch:
- platform: broadlink
  mac: B4:43:0D:AA:40:18
  switches:
    - name: tv on/off
      command_on: JgA0ACETFBQVMBQvFxIULxQUFS4VFhIzEzAUAAFfJRETFBMvFTAUExQvFRMVMBMTFC8VLxYADQUAAAAA=
    - name: tv select/ok
      command_on: JgBKAAoADFEIAAOOCToHAAGaCQABHyETFCUWEhQiFCUUExQTFC8VHxITFC8VAAGaIxIUJRUTFB4UJRQTFBMULxUdFBMUMBUABEIHAA0FAAAAAAAAAAAAAAAAAAA=
    - name: tv up
      command_on: JgBAAAiqCQABlAiVIhQTJRYTEx8SJRUTFBQTHRYcFCcTLxUAAZwhFBMmFBIVHRQmFBMUFBMdFB0UJRUwFAAFpAgADQUAAAAAAAAAAA==
    - name: tv down
      command_on: JgA8AAjSCQABjwpaIhQTJhYSFB0UJRUUFBQTHhMnFCUVFRIAAa0iExQmFBMUHRQmFRQTFBMeEyUVJRUUEwANBQAAAAAAAAAAAAAAAA==
    - name: tv left
      command_on: JgA4ACEUEyUVFBMdFCYUExUTFCUWLhUdFB0UAAGaIxMTJRUTFB4UJRQTFBUSJRUxEx0UHhMAAfAHAA0F
    - name: tv right
      command_on: JgBAAAcABxcJAALkJBQTJhQTFB0WJBgVEhMUMBQUFBMTJRUAAa0jFRUlFRIUHRQmFBQTExQwFBQTFBMlFQAEbAkADQUAAAAAAAAAAA==
    - name: tv back
      command_on: JgCcACQSFUIVExYeEyQXEhQTFBwWLR0jFxwVAAGSJREXJBUSFhsVIxcTFBIVHBQuFiUWHBUAAZIlEhQkFxIVGxUkFhIWEhUbFS4WJRYbGAABlCMSFSQWEhUdFSQVEhYSFB0ULRcjFxwUAAGUJRIVJBcRFRsWJRURGBEWGhYtFiQWHRQAAZUjEhckFRIVGxYlFRMUEhUbFi4VJRYbFQANBQAAAAAAAAAAAAAAAA==
    - name: tv home
      command_on: JgBAAAlnCRQIAAJzIRMUJRYSFB4TJRUUExMYJhQTFR0WJjUAAawlEBUlFRMUHxImFRMVExMmFBIVHRQmFAAERQgADQUAAAAAAAAAAA==
    - name: tv menu
      command_on: JgBMAAi7BwABlAh+IhMUJhUUEh8SJRUVFBEVHhQSFCYUJhQAAa0jFxMmFBMUHhMlFRQVEhQgExQTJRYlFAAE+wcAAk4IAAGACAACogkADQUAAAAAAAAAAAAAAAA=
    - name: tv volumedown
      command_on: JgA6AAj0CAAB/SUUEyUVFRMdEyYUExQUFC8UMRMTFB4UAAGZIhIVJhQUEx0VJBUSFRMVMBUvFBMUHRQADQUAAAAAAAAAAAAAAAAAAA==
    - name: tv volumeup
      command_on: JgBEAAcAAVwIAAFJCCgiExUlFRMUHRMnExMUFBQuFyMVFBMVEwABrCISFSUWExMfEiUVExUTEy4iJRYTExMUAAZ4CA0PAA0FAAAAAA==
    #- name: tv mute
      #command_on: JgBCAgoAAzcjExQjFhIUGxUjFhQTExQtFSwWEhUbFAABmyQRFyMVERUcFyIVEhUSFC0WLBYSFBwVAAGaJBEWIxYSFBsVIxYTFBIULBgsFRIUGxVQCQABQiQRFyMVERscFSIWEhYRFCwXLBYSFBwUAAGbJREVIhcSFBsWIxYQFxEULBgrFhEVGxYAAZwjERYkFREVGxYjFREWEhQtFi4UERUcFAABmyUQFiIYERQbFiIWERYRFS0WLRUSFRoVAAGfJREVIxcRFBsVIxYSFhAWLBYsFhIVGhYAAZskEhUjFxEUHBQkFRMUERUsFy0WERUaFwABmyQRFiIXERQbFSMWEhURFiwXLBUSFRoXAAGZJRAXIxURFhsVIhYTFBEVLBcsFhEWGhcAAZklEBciFhEWGhUlFREVERYsFiwXERQbFQABmyQTFSIXERUbFSQVERYRFSwXLBcRFB0TAAGbJBMWIhYRFRsVJBUSFREVLhUsFhEVHBQAAZ4jEhUjFhEVGxUjFhMVERQsFywXEhUaFwABmSQRFiQVERUcFCMWExURFCwXLBYRFxkWAAGbJRMUJBYSFBsVIxcRFhAVLRYsFxIUGhYAAZolERZIFhEWGxUiGBEUERUtFiwWEhUdEwABmiQSFSQWEhUaFyYVEBYRFi0VLBcSFBsVAAGaJREWIhYRFhsUJBcQFRIULhUsFxIUGxUAAZwlEhYjFhAWGhYkFRMTEhUsFiwXEhQbFQABmiQSFiIXERUaFiMXEBUSFSwWLBchFhoVAA0FFywVEhUa
发表于 2022-2-6 19:35:50 | 显示全部楼层
自己正好在学电视的,看到好多人问,直接写了个最新的HASS官方推荐的方法:https://bbs.hassbian.com/thread-15306-1-1.html
 楼主| 发表于 2022-2-6 20:04:45 | 显示全部楼层
Tao173 发表于 2022-2-6 16:59
类似于这样,switch.yaml里面写。你没有的话config那个文件写应该也行。另外你这发了几个帖子。。。。相同 ...
谢大神,那几个帖子不是我发的
 楼主| 发表于 2022-2-6 20:10:20 | 显示全部楼层
sctale 发表于 2022-2-6 19:35
自己正好在学电视的,看到好多人问,直接写了个最新的HASS官方推荐的方法:https://bbs.hassbian.com/threa ...
正在学您的帖子
发表于 2022-2-6 20:43:46 来自手机 | 显示全部楼层
没必要创建实体,在lovelace建button,动作选调用服务
 楼主| 发表于 2022-2-6 20:46:45 | 显示全部楼层
还玩不了那么高端,我刚开始弄这东西,从最基础的来
发表于 2022-2-7 17:03:33 | 显示全部楼层
以上几位是取得了遥控编码后在配置文件里添加按钮实体的,我是通过ha自带的功能学习保存相应的遥控命令,然后在脚本中调用。
如上图,在开发者工具里调用 Learn Command学习保存了mitv的power命令后,就可以通过Send Command来调用前面的命令,编写在脚本里就是这样的:
alias: mitv_power
sequence:
    target:
      entity_id: remote.bo_lian_zhi_neng_yao_kong_remote
    data:
      device: mitv
      command: power
mode: single
以上是红外遥控的学习使用,如果是射频的,就在学习时,把command type勾选,后面的列表框里把IR改为RF。调用时的方法,红外跟射频没有区别。
 楼主| 发表于 2022-3-20 10:05:23 | 显示全部楼层
cjnt007 发表于 2022-2-7 17:03
以上几位是取得了遥控编码后在配置文件里添加按钮实体的,我是通过ha自带的功能学习保存相应的遥控命令,然 ...
可以的
GMT+8, 2026-1-19 15:25 , Processed in 1.765085 second(s), 15 queries , MemCached On.
