查看: 9585|回复: 15
[基础教程] 基于Docker安装的HASS升级
发表于 2022-2-4 13:34:53 | 显示全部楼层 |阅读模式
基于Docker安装的HASS升级
拉取最新镜像
docker pull homeassistant/home-assistant:latest停止容器docker stop [容器ID]
## 例如
root@hass:~# docker ps
CONTAINER ID   IMAGE                                 COMMAND   CREATED       STATUS       PORTS     NAMES
e9bf23f4ba60   homeassistant/home-assistant:latest   "/init"   4 weeks ago   Up 4 weeks             home-assistants
root@hass:~# docker stop e9bf23f4ba60
e9bf23f4ba60
删除容器
docker rm [容器ID]
## 例如
root@hass:~# docker ps -a
e9bf23f4ba60   dd42f613ab5e   "/init"   4 weeks ago   Exited (0) 8 minutes ago             home-assistants
root@hass:~# docker rm e9bf23f4ba60
home-assistants
启动最新的镜像
docker run -d --restart=always --name="home-assistants" --privileged=true   -e TZ=Asia/Shanghai  -v /data/homeassistant/config:/config --net=host homeassistant/home-assistant:latest
删除老的镜像
root@hass:~# docker images
REPOSITORY                     TAG       IMAGE ID       CREATED       SIZE
homeassistant/home-assistant   latest    149c6cb3c7b0   2 hours ago   1.08GB
homeassistant/home-assistant   <none>    dd42f613ab5e   4 weeks ago   1.07GB
root@hass:~# docker rmi dd42f613ab5e
Untagged: homeassistant/home-assistant@sha256:81d381f5008c082a37da97d8b08dd8b358dae7ecf49e62ce3ef1eeaefc4381bb
Deleted: sha256:dd42f613ab5e08e2c86213637a35a0236fe92da10c125cbb1e534ae8f3a30e06
Deleted: sha256:150068301e804a0e7ca227b0627e3ba6b0e58e773a4ecf8d3374f233c42625be
Deleted: sha256:d3b72bd7807716b3ca3527457901d411a44718ada5a17c3c4491f5c2f0780564
Deleted: sha256:b2cab2c340329d3fef6199a2771b78ee5960d56ace741bd22676b7dc445f43bc
Deleted: sha256:aa44e26ebf7696e3b296e4b245440aea746ec7f9528e3904df55b0294467f71f
Deleted: sha256:1c905f9de49a5df4845fff4c3ff53b9309e2af1c7aa8f41476018209491e485b
Deleted: sha256:68746c3716019882370cf67936c233ac9aeec0d0bc73a0947f7ddd017fc43a0e
Deleted: sha256:2bde53d5333eb04d25a7a64cdfbdc01094db80d4a6838d8e85786469007d655f
Deleted: sha256:a000359b80091e5816625ea577c8eac0d49f94c12b26fab5abe19ac5157a0a1b
Deleted: sha256:db8fc40bd21bbbf6e7859e2f109cc8ffa7ce1c0320eedc8744b6d6fa27df0ab8
Deleted: sha256:e6117062f12806812644982f0a6ff1ac8031e94d0813bea7159a97b4435d7ad3
mitu 手机认证
发表于 2022-2-4 15:45:02 | 显示全部楼层
docker exec -it home-assistants pip3 install --upgrade homeassistant
也可以这样升级而不用重新拉镜像
 楼主| 发表于 2022-2-4 16:02:56 | 显示全部楼层
也可以这样升级而不用重新拉镜像 ...
感谢老铁提供的新方法
发表于 2022-2-11 18:45:55 | 显示全部楼层
标注收藏
发表于 2023-9-18 22:00:37 | 显示全部楼层
也可以这样升级而不用重新拉镜像 ...
这个牛比! 好像得把中间的home-assistants换成自己的容器名
发表于 2023-10-9 17:17:56 | 显示全部楼层
这样更新,ha里面的各种配置、插件什么的是不是得从新安装调试?能复用吗?
发表于 2023-10-13 22:36:11 | 显示全部楼层
mark备用
007潜水了
发表于 2023-10-15 08:10:14 | 显示全部楼层
pisice 发表于 2023-10-9 17:17
这样更新,ha里面的各种配置、插件什么的是不是得从新安装调试?能复用吗? ...
能的,我就是每次要升级重新拉最新stable镜像
只要两个版本间配置文件内容兼容就可以配置目录volume挂到本地
发表于 2023-10-18 10:56:36 | 显示全部楼层
只要两个版本间配置文件内容兼容就可以配置目录volume挂到 ...
已实践,谢谢!
发表于 2024-2-27 13:27:44 | 显示全部楼层
群晖的套件里面的docker 部署的hass,没有找到python,deps下面是空的,该怎么找python
日志提示去这里找,但是这里也没有python3.12/这个目录
Logger: pyicloud.base
Source: /usr/local/lib/python3.12/site-packages/pyicloud/base.py:188
First occurred: 18:11:15 (1 occurrences)
Last logged: 18:11:15
Authentication required for Account. (421)
GMT+8, 2026-1-14 21:12 , Processed in 0.061265 second(s), 13 queries , MemCached On.
