查看: 2897|回复: 4
[求助] 涉及到云端的集成都不能使用了,有相同情况吗?求解决
发表于 2022-1-28 10:30:18 | 显示全部楼层 |阅读模式
网络情况:移动宽带集成:xiaomi miot , 彩云天气, HACS、speedtest
状况:1月26日早上收到短信,小区网络维修,维修完重启了HASS,然后就发现涉及到云端的集成都报错了,本地的集成还正常使用。求大神指点怎么解决。报错信息如下:
彩云天气:
此错误来自自定义集成。
Logger: custom_components.colorfulclouds
Source: helpers/update_coordinator.py:200
Integration: colorfulclouds (documentation, issues)
First occurred: 09:41:15 (31 occurrences)
Last logged: 10:19:39
Error requesting colorfulclouds data: HTTPSConnectionPool(host='api.caiyunapp.com', port=443): Max retries exceeded with url: /v2.5/XXXXXXXXXXXXXXXX/XXXXXXXXXXX/weather.json?dailysteps=5&hourlysteps=24&alert=True&unit=metric:v2&timestamp=1643336034 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8bb4fc70>: Failed to establish a new connection: [Errno -3] Try again'))
Error requesting colorfulclouds data: HTTPSConnectionPool(host='api.caiyunapp.com', port=443): Max retries exceeded with url: /v2.5/XXXXXXXXXXXXXXXX/XXXXXXXXXXX/weather.json?dailysteps=5&hourlysteps=24&alert=True&unit=metric:v2&timestamp=1643336119 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8ba46820>: Failed to establish a new connection: [Errno -3] Try again'))
Error requesting colorfulclouds data: HTTPSConnectionPool(host='api.caiyunapp.com', port=443): Max retries exceeded with url: /v2.5/XXXXXXXXXXXXXXXX/XXXXXXXXXXX/weather.json?dailysteps=5&hourlysteps=24&alert=True&unit=metric:v2&timestamp=1643336204 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8a6d8d30>: Failed to establish a new connection: [Errno -3] Try again'))
Error requesting colorfulclouds data: HTTPSConnectionPool(host='api.caiyunapp.com', port=443): Max retries exceeded with url: /v2.5/XXXXXXXXXXXXXXXX/XXXXXXXXXXX/weather.json?dailysteps=5&hourlysteps=24&alert=True&unit=metric:v2&timestamp=1643336289 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f88d9ef10>: Failed to establish a new connection: [Errno -3] Try again'))
Error requesting colorfulclouds data: HTTPSConnectionPool(host='api.caiyunapp.com', port=443): Max retries exceeded with url: /v2.5/XXXXXXXXXXXXXXXX/XXXXXXXXXXX/weather.json?dailysteps=5&hourlysteps=24&alert=True&unit=metric:v2&timestamp=1643336374 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f88d97370>: Failed to establish a new connection: [Errno -3] Try again'))
HACS的报错信息:
此错误来自自定义集成。
Logger: custom_components.hacs
Source: custom_components/hacs/base.py:478
Integration: HACS (documentation, issues)
First occurred: 09:41:18 (1 occurrences)
Last logged: 09:41:18
Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
  File "/config/custom_components/hacs/base.py", line 427, in async_can_update
    response = await self.async_github_api_method(self.githubapi.rate_limit)
  File "/config/custom_components/hacs/base.py", line 478, in async_github_api_method
    raise HacsException(_exception)
custom_components.hacs.exceptions.HacsException: Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
还有一个报错信息,不知道是啥集成的,如下:
Logger: homeassistant.components.updater
Integration: 更新提示 (documentation, issues)
First occurred: 09:41:15 (1 occurrences)
Last logged: 09:41:15
Error requesting Home Assistant update data: Cannot connect to host www.home-assistant.io:443 ssl:default [Try again]
wtda
发表于 2022-1-28 12:15:26 | 显示全部楼层
HACS的报错信息,今天才看到的帖子,你研究研究?手把手教你解决HACS无法访问github问题:无需科学上网
彩云的不太懂哎,要不你重装试试?
 楼主| 发表于 2022-1-28 14:56:07 | 显示全部楼层
彩 ...
这个已经搞过啦,之前能正常访问的时候就搞过了,很好能正常使用。但这一整啥也不能用了
发表于 2022-1-28 15:22:56 | 显示全部楼层
我中午也遇到同样的问题,禁用再启用小米集成解决
 楼主| 发表于 2022-1-28 17:02:45 | 显示全部楼层
刚才升级hass系统了,中间来回重启了很多遍,莫名奇妙又好了
GMT+8, 2025-11-6 04:20 , Processed in 0.087812 second(s), 11 queries , MemCached On.
