查看: 3750|回复: 5
[技术探讨] 华硕的集成不能用device tracker了吗,今天刚从2021.1更新到最新
发表于 2022-1-26 03:13:19 | 显示全部楼层 |阅读模式
各位好,请教一下华硕的集成不能用device tracker了吗,今天刚从2021.1更新到最新 Snipaste_2022-01-26_03-00-48.jpg
发表于 2022-1-26 13:18:06 | 显示全部楼层
在配置-设备与服务,通过UI界面配置
 楼主| 发表于 2022-1-26 17:18:31 | 显示全部楼层
chenquanhao 发表于 2022-1-26 13:18
在配置-设备与服务,通过UI界面配置
大佬你好,是在这里吗,没有找到device_tracker相关实体,只有一个sensor.asuswrt_devices_connected 的实体,这个好像是显示链接数量的
发表于 2022-1-26 20:53:08 | 显示全部楼层
很久没用这个集成了,以前有device_tracker的
发表于 2022-1-27 00:34:48 | 显示全部楼层
点选项,选中track unknown/unamed devices
 楼主| 发表于 2022-1-28 23:06:08 | 显示全部楼层
已找到官方文档 从这个版本开始配置文件需要变动
https://www.home-assistant.io/bl ... 3/#breaking-changes
The legacy device tracker DeviceScanner was replaced with the new device tracker implementation ScannerEntity.
You should remove references to platform asuswrt in device_tracker section in your YAML configuration and update person device tracker with the new entity.
The YAML key dnsmasq, interface and require_ip now are managed as integration options. The values present in YAML are imported in the options the first time that the integration is loaded.
All sensors are initially created as disabled and can be enabled from ASUSWRT device configuration instead of using YAML configuration.
GMT+8, 2026-1-19 21:09 , Processed in 1.368026 second(s), 9 queries , MemCached On.
