查看: 11215|回复: 4
[经验分享] 树莓派安装Homebridge之老高大神教程补充
发表于 2017-10-21 02:28:28 | 显示全部楼层 |阅读模式
搞定源的问题之后到最后一步生成config.json安装老高大大的教程写的config.json结果报错,截图如下:
然后去群里提问,遇到深夜大神指导附上截图:
贴上我的config.json文件:
    "bridge": {
        "name": "Homebridge",
        "username": "树莓mac",
        "port": 51826,
        "pin": "000-00-025"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://树莓派IP:8123",
    "password": "raspberry",
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"],  (这个后面加一个英文的,号)
    "default_visibility": "visible"    (加上这一句就不报错了)
具体解释参照老高大大的教程
最后附上安装完毕图:
搞完config.json之后是打开打开MQTT的服务跟建立Samba服务
安装老高大神给的命令集合输入开启MQTT服务代码发现居然没有这个服务,在网上各种找,最后找到方法了附上截图:
解决方法如下:
安装MQTT服务
输入一下代码就可完成安装
sudo apt-get install libssl-dev
sudo apt-get install libc-ares-dev
sudo apt-get install uuid-dev
sudo apt-get install mosquitto
###开启服务
sudo systemctl start mosquitto
####查看服务状态
sudo systemctl status mosquitto
然后在按照老高大神的教程继续就可以安装完成。附上帖子原地址:baso0204分享的教程,借花献佛了
如果后续还发现问题,还会在这里更新一下解决办法,前提是我能找的到。。哈哈哈
 楼主| 发表于 2017-10-21 03:42:03 | 显示全部楼层
沙发自己坐
发表于 2017-10-21 11:10:24 | 显示全部楼层
感谢分享,权限奉上!
发表于 2017-10-27 23:21:22 | 显示全部楼层
为你点个赞
发表于 2017-10-30 13:20:59 | 显示全部楼层
pi@hassbian:~ $ sudo systemctl start mosquitto
pi@hassbian:~ $ sudo systemctl status mosquitto
● mosquitto.service - Insite MQTT Broker
   Loaded: loaded (/etc/systemd/system/mosquitto.service; enabled)
   Active: failed (Result: exit-code) since Mon 2017-10-30 00:49:20 CST; 7s ago
  Process: 1624 ExecStart=/usr/local/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 1624 (code=exited, status=1/FAILURE)
Oct 30 00:49:20 hassbian systemd[1]: Started Insite MQTT Broker.
Oct 30 00:49:20 hassbian mosquitto[1624]: 1509295760: mosquitto version 1.4....g
Oct 30 00:49:20 hassbian systemd[1]: mosquitto.service: main process exited...RE
Oct 30 00:49:20 hassbian systemd[1]: Unit mosquitto.service entered failed ...e.
Oct 30 00:49:20 hassbian mosquitto[1624]: 1509295760: Config loaded from /et....
Oct 30 00:49:20 hassbian mosquitto[1624]: 1509295760: Opening ipv4 listen so....
Oct 30 00:49:20 hassbian mosquitto[1624]: 1509295760: Error: Address already...e
Hint: Some lines were ellipsized, use -l to show in full.
求助  没法设定开机启动
这个报错该怎么解决
GMT+8, 2025-9-7 04:56 , Processed in 0.054563 second(s), 14 queries , MemCached On.
