查看: 2393|回复: 2
[已解决] 如何将command_line获取到的json数组转换为input_select的options?
发表于 2022-1-5 19:53:10 | 显示全部楼层 |阅读模式
["176x144", "208x144", "240x160", "352x288", "320x240", "480x320", "640x480", "800x480", "720x720", "960x544", "960x720", "1280x720", "1280x960", "1920x1088"]
如上,可以通过command_line获取到摄像头的分辨率列表,打算添加到input_select中选项列表中,然后更改不同选项以实现分辨率的切换。
我大概查询了论坛里对input_select的使用,目前只看到在yaml中写死其选项列表,是否根据查询到的值动态构造它的选项列表?
请各路大侠不吝赐教!
佑桑
发表于 2022-1-5 21:14:23 | 显示全部楼层
service: input_select.set_options
target:
  entity_id: input_select.blahblah
data:
  options: ["176x144", "208x144", "240x160", "352x288", "320x240", "480x320", "640x480", "800x480", "720x720", "960x544", "960x720", "1280x720", "1280x960", "1920x1088"]
https://www.home-assistant.io/integrations/input_select/#services
 楼主| 发表于 2022-1-5 21:59:57 | 显示全部楼层
多谢,多谢!又学了一招
GMT+8, 2025-12-22 03:38 , Processed in 0.112061 second(s), 7 queries , MemCached On.
