查看: 4270|回复: 5
[技术探讨] ESPHOME 接收433信号设置为点动开关
发表于 2022-1-4 02:33:02 | 显示全部楼层 |阅读模式
请问怎样修改这个代码为按一下遥控器   传感器状态 变为开启后 1秒后自动变回关闭状态?
现在的状态是按一下遥控器 开启,再按一下遥控器 才关闭。这样子不好做自动化。
请求各位帮个忙修改下。谢谢
remote_receiver:
  pin: GPIO2
  dump:
    - rc_switch
  tolerance: 50%
  filter: 250us
  idle: 4ms
  buffer_size: 2kb
binary_sensor:
# 1  433遥控器
  - platform: template
  - platform: remote_receiver
    internal: true
    rc_switch_raw:
      code: "000111011110010110001010"
      protocol: 1
    filters:
      delayed_off: 100ms
    on_press:
      if:
        condition:
          binary_sensor.is_on: a433button
        then:
          - binary_sensor.template.publish:
              state: OFF
        else:
              state: ON
发表于 2022-1-4 07:46:21 | 显示全部楼层
我是用的写成scripts的办法 就是一个 执行 按键了 没有状态反馈
发表于 2022-1-4 12:14:27 | 显示全部楼层
delay: 1s 然后关闭
 楼主| 发表于 2022-1-4 17:11:29 来自手机 | 显示全部楼层
hunterfox 发表于 2022-1-4 12:14
delay: 1s 然后关闭
请问怎样修改?谢谢
发表于 2022-1-4 17:20:57 | 显示全部楼层
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: " "
  password: " "
  fast_connect: True
  use_address: 10.0.0.30  # 指定烧录固件时候目标设备IP,优先级高于静态IP
  manual_ip:
    static_ip:
    gateway:
    subnet:
    dns1:
    dns2:
  ap:
    ssid: "Dswitch Computer"
    password: " "
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
  auth:
    username: admin
    password: ''
switch:
  - platform: gpio
    pin: 14
    inverted: true
    icon: "mdi:computer"
    turn_on_action:
    - switch.turn_on: relay
    - delay: 500ms            # 打开后延时500ms后设置为关
    - switch.turn_off: relay
  - platform: gpio
    pin: 16
    inverted: true
    turn_on_action:
    - switch.turn_on: relay2
    - delay: 500ms
    - switch.turn_off: relay2
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO4
      inverted: false
      mode: INPUT_PULLUP
    name: "Study Computer"
    device_class: power
这个可以参考下。
 楼主| 发表于 2022-1-4 23:32:45 来自手机 | 显示全部楼层
mildrabbit 发表于 2022-1-4 17:20
esphome:
  platform: ESP8266
你这代码是开关代码自动复位是没问题,但传感器不适用这代码。
GMT+8, 2026-1-6 19:54 , Processed in 0.172876 second(s), 11 queries , MemCached On.
