楼主: huang7dede
[流程系列] [node-red]【2023.11.07】撸了个EDGE语音引擎的TTS节点,音质不错
 楼主| 发表于 2021-12-23 21:19:43 | 显示全部楼层
dinglifeng 发表于 2021-12-23 19:40
呃  您有相关的文档资料么 我有点懵逼 不知道怎么在命令行情况下进入node-red系统 ...
没安装过hassos,,所以我也是一窍不通啊
发表于 2021-12-23 21:24:23 | 显示全部楼层
您赶快修修 能在线安装就省心了
发表于 2021-12-24 10:48:36 | 显示全部楼层
谢谢分享
发表于 2021-12-24 11:25:37 | 显示全部楼层
看看我怎么记得我回过
发表于 2021-12-24 12:34:28 | 显示全部楼层
老大 进来了 可以进 nodered了 可是安装提示错误
root@ccf28a08-nodered:/$ cd config
root@ccf28a08-nodered:/config$ cd node-red
root@ccf28a08-nodered:/config/node-red$ cd data
root@ccf28a08-nodered:/config/node-red/data$ npm install /data/node-red-contrib-edge-tts/
npm ERR! code ENOENT
npm ERR! syscall open
npm ERR! path /data/node-red-contrib-edge-tts/package.json
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, open '/data/node-red-contrib-edge-tts/package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-12-24T04_32_55_269Z-debug.log
发表于 2021-12-24 12:57:20 | 显示全部楼层
用群晖docker 不会装
发表于 2021-12-24 12:57:23 | 显示全部楼层
你没有吧 解压的文件放到你执行的目录下,肯定错报,因为就没有那个文件
发表于 2021-12-24 13:05:51 | 显示全部楼层
QQ617250210 发表于 2021-12-24 12:57
你没有吧 解压的文件放到你执行的目录下,肯定错报,因为就没有那个文件 ...
放进来了 运行完了 还是没有……
root@ccf28a08-nodered:/config/node-red$ npm install node-red-contrib-edge-tts
npm WARN deprecated [email protected]: core-js@<3.4 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Please, upgrade your dependencies to the actual version of core-js.
added 157 packages, and audited 571 packages in 27s
54 packages are looking for funding
  run `npm fund` for details
10 vulnerabilities (5 moderate, 5 high)
发表于 2021-12-24 13:15:19 | 显示全部楼层
向大佬学习
发表于 2021-12-24 13:20:58 | 显示全部楼层
试了半天
root@ccf28a08-nodered:/opt$ npm install /config/node-red/data/node-red-contrib-edge-tts/
npm WARN EBADENGINE Unsupported engine {
npm WARN EBADENGINE   package: '[email protected]',
npm WARN EBADENGINE   required: { node: '>=10 <15' },
npm WARN EBADENGINE   current: { node: 'v16.13.1', npm: '8.1.3' }
npm WARN EBADENGINE }
但查看modbus版本已经是最新的了
added 18 packages, and audited 709 packages in 11s
GMT+8, 2025-12-16 14:31 , Processed in 1.354738 second(s), 6 queries , MemCached On.
