楼主: muxiachuixue
[学习笔记] 干货:解决supervisor商店插件add-ons无法加载的问题
 火.. [复制链接]
发表于 2022-4-7 14:27:06 | 显示全部楼层
muxiachuixue 发表于 2022-4-7 13:23
输入login进入宿主机,然后再输入帖子中的代码
Welcome to Alpine!
The Alpine Wiki contains a large amount of how-to guides and general
information about administrating Alpine systems.
See <http://wiki.alpinelinux.org/>.
You can setup the system with the command: setup-alpine
You may change this message by editing /etc/motd.
| |  | |                          /\           (_)   | |            | |
| |__| | ___  _ __ ___   ___     /  \   ___ ___ _ ___| |_ __ _ _ __ | |_
|  __  |/ _ \| '_ \ _ \ / _ \   / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| |  | | (_) | | | | | |  __/  / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_|  |_|\___/|_| |_| |_|\___| /_/    \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
  IPv4 addresses for enp0s3: 192.168.31.83/24
  IPv6 addresses for enp0s3: fe80::baf3:a7a:833a:2543/64
  OS Version:               Home Assistant OS 7.6
  Home Assistant Core:      2022.4.0
  Home Assistant URL:       http://homeassistant.local:8123
  Observer URL:             http://homeassistant.local:4357
➜  ~ docker exec -i hassio_supervisor /bin/bash -lc 'sh /data/homeassistant/replace_supervisor_addon_url.sh'
PROTECTION MODE ENABLED!
To be able to use this command, you'll need to disable
protection mode on this add-on. Without it, the add-on
is unable to access Docker.
Steps:
- Go to the Configuration Panel.
- Enter the 'Add-ons, Backups & Supervisor' menu.
- Click on the SSH & Web Terminal add-on.
- Set the 'Protection mode' switch to off.
- Restart the add-on.
Access to Docker allows you to do really powerful things
including complete destruction of your system.
Please, be sure you know what you are doing before enabling
this feature!
发表于 2022-4-7 14:29:12 | 显示全部楼层
wt63230233 发表于 2022-4-7 14:27
Welcome to Alpine!
哦,我知道了,得关闭保护模式
发表于 2022-4-7 16:08:53 | 显示全部楼层
感谢,楼主, 部分插件正在安装!
发表于 2022-4-15 12:48:09 | 显示全部楼层
Home Assistant Community Add-ons 的插件显示了,但是Official add-ons 的插件就不显示了,两者不能一起生存吗?
 楼主| 发表于 2022-4-15 13:44:56 | 显示全部楼层
donggua 发表于 2022-4-15 12:48
Home Assistant Community Add-ons 的插件显示了,但是Official add-ons 的插件就不显示了,两者不能一起生 ...
可以一起的。看看supervisor的日志,镜像有没有替换成功
发表于 2022-4-16 17:05:58 | 显示全部楼层
谢谢分享,但是我宿主机怎么提示没crontab,用的ova的haos
发表于 2022-4-18 11:48:20 | 显示全部楼层
hxck 发表于 2022-3-2 00:26
大佬,怎么进宿主机呀,我用homeassistant的ssh网页版进去直接粘贴docker命令不行
你的问题解决了吗?
我是用树莓派安装的HASSOS,一直不知道怎么进宿主,直接树莓派键盘输入好像不行
发表于 2022-4-23 03:07:21 | 显示全部楼层
我按你说的做到第二步,就无法重启HA了,
提示是Error loading /config/configuration.yaml: 'utf-8' codec can't decode byte 0xc6 in position 116: invalid continuation byte
我用的是HA里的File editor编辑的?这是什么原因?
只有把homeassistant:
这个删除掉,才行。
 楼主| 发表于 2022-4-23 10:07:11 | 显示全部楼层
提示是Error loading /config/configuration.yaml: 'utf-8' codec ...
你是不是回复错了,在另外一个帖子里吧。文件编码的问题,在linux环境下编辑应该没这个问题,或者你直接把自动化的代码复制到configuration.yaml文件里面,不要用 packages了。
发表于 2022-5-4 22:03:19 | 显示全部楼层
sh: can't open '/root/replace_supervisor_addon_url.sh': No such file or directory
GMT+8, 2026-2-14 12:42 , Processed in 0.011729 second(s), 3 queries , Redis On.
