查看: 3971|回复: 7
[技术探讨] 求小米电视魅族遥控器可用的红外遥控码
发表于 2021-12-21 10:23:24 | 显示全部楼层 |阅读模式
小米电视已通过 https://github.com/shaonianzhentan/xiaomi_tv 教程接入HA,开机唤醒需要红外码,小米电视4自带蓝牙遥控器,现求魅族遥控器可用的红外吗,有学码成功的大神麻烦分享下
发表于 2021-12-21 10:50:03 | 显示全部楼层
排队等下,再求下乐视TV
 楼主| 发表于 2021-12-21 11:01:50 | 显示全部楼层
pingzi 发表于 2021-12-21 10:50
排队等下,再求下乐视TV
乐视的 @jiluxinqing 大神有分享的了
https://github.com/shaonianzhentan/meizu_ble
发表于 2021-12-21 13:36:23 | 显示全部楼层
- platform: broadlink
  mac: B4:43:0D:AA:40:18
  switches:
    - name: tv on/off
      command_on: JgA0ACETFBQVMBQvFxIULxQUFS4VFhIzEzAUAAFfJRETFBMvFTAUExQvFRMVMBMTFC8VLxYADQUAAAAA=
    - name: tv select/ok
      command_on: JgBKAAoADFEIAAOOCToHAAGaCQABHyETFCUWEhQiFCUUExQTFC8VHxITFC8VAAGaIxIUJRUTFB4UJRQTFBMULxUdFBMUMBUABEIHAA0FAAAAAAAAAAAAAAAAAAA=
    - name: tv up
      command_on: JgBAAAiqCQABlAiVIhQTJRYTEx8SJRUTFBQTHRYcFCcTLxUAAZwhFBMmFBIVHRQmFBMUFBMdFB0UJRUwFAAFpAgADQUAAAAAAAAAAA==
    - name: tv down
      command_on: JgA8AAjSCQABjwpaIhQTJhYSFB0UJRUUFBQTHhMnFCUVFRIAAa0iExQmFBMUHRQmFRQTFBMeEyUVJRUUEwANBQAAAAAAAAAAAAAAAA==
    - name: tv left
      command_on: JgA4ACEUEyUVFBMdFCYUExUTFCUWLhUdFB0UAAGaIxMTJRUTFB4UJRQTFBUSJRUxEx0UHhMAAfAHAA0F
    - name: tv right
      command_on: JgBAAAcABxcJAALkJBQTJhQTFB0WJBgVEhMUMBQUFBMTJRUAAa0jFRUlFRIUHRQmFBQTExQwFBQTFBMlFQAEbAkADQUAAAAAAAAAAA==
    - name: tv back
      command_on: JgCcACQSFUIVExYeEyQXEhQTFBwWLR0jFxwVAAGSJREXJBUSFhsVIxcTFBIVHBQuFiUWHBUAAZIlEhQkFxIVGxUkFhIWEhUbFS4WJRYbGAABlCMSFSQWEhUdFSQVEhYSFB0ULRcjFxwUAAGUJRIVJBcRFRsWJRURGBEWGhYtFiQWHRQAAZUjEhckFRIVGxYlFRMUEhUbFi4VJRYbFQANBQAAAAAAAAAAAAAAAA==
    - name: tv home
      command_on: JgBAAAlnCRQIAAJzIRMUJRYSFB4TJRUUExMYJhQTFR0WJjUAAawlEBUlFRMUHxImFRMVExMmFBIVHRQmFAAERQgADQUAAAAAAAAAAA==
    - name: tv menu
      command_on: JgBMAAi7BwABlAh+IhMUJhUUEh8SJRUVFBEVHhQSFCYUJhQAAa0jFxMmFBMUHhMlFRQVEhQgExQTJRYlFAAE+wcAAk4IAAGACAACogkADQUAAAAAAAAAAAAAAAA=
    - name: tv volumedown
      command_on: JgA6AAj0CAAB/SUUEyUVFRMdEyYUExQUFC8UMRMTFB4UAAGZIhIVJhQUEx0VJBUSFRMVMBUvFBMUHRQADQUAAAAAAAAAAAAAAAAAAA==
    - name: tv volumeup
      command_on: JgBEAAcAAVwIAAFJCCgiExUlFRMUHRMnExMUFBQuFyMVFBMVEwABrCISFSUWExMfEiUVExUTEy4iJRYTExMUAAZ4CA0PAA0FAAAAAA==
    #- name: tv mute
      #command_on: JgBCAgoAAzcjExQjFhIUGxUjFhQTExQtFSwWEhUbFAABmyQRFyMVERUcFyIVEhUSFC0WLBYSFBwVAAGaJBEWIxYSFBsVIxYTFBIULBgsFRIUGxVQCQABQiQRFyMVERscFSIWEhYRFCwXLBYSFBwUAAGbJREVIhcSFBsWIxYQFxEULBgrFhEVGxYAAZwjERYkFREVGxYjFREWEhQtFi4UERUcFAABmyUQFiIYERQbFiIWERYRFS0WLRUSFRoVAAGfJREVIxcRFBsVIxYSFhAWLBYsFhIVGhYAAZskEhUjFxEUHBQkFRMUERUsFy0WERUaFwABmyQRFiIXERQbFSMWEhURFiwXLBUSFRoXAAGZJRAXIxURFhsVIhYTFBEVLBcsFhEWGhcAAZklEBciFhEWGhUlFREVERYsFiwXERQbFQABmyQTFSIXERUbFSQVERYRFSwXLBcRFB0TAAGbJBMWIhYRFRsVJBUSFREVLhUsFhEVHBQAAZ4jEhUjFhEVGxUjFhMVERQsFywXEhUaFwABmSQRFiQVERUcFCMWExURFCwXLBYRFxkWAAGbJRMUJBYSFBsVIxcRFhAVLRYsFxIUGhYAAZolERZIFhEWGxUiGBEUERUtFiwWEhUdEwABmiQSFSQWEhUaFyYVEBYRFi0VLBcSFBsVAAGaJREWIhYRFhsUJBcQFRIULhUsFxIUGxUAAZwlEhYjFhAWGhYkFRMTEhUsFiwXEhQbFQABmiQSFiIXERUaFiMXEBUSFSwWLBchFhoVAA0FFywVEhUa
 楼主| 发表于 2021-12-21 14:42:12 | 显示全部楼层
博联和魅族的通用的吗?
发表于 2021-12-21 15:01:52 | 显示全部楼层
fz雪之汐若 发表于 2021-12-21 14:42
博联和魅族的通用的吗?
不知道,红外码一样的吧,试试看
发表于 2021-12-21 15:56:10 | 显示全部楼层
感谢 回复~!~
 楼主| 发表于 2022-1-20 21:59:31 | 显示全部楼层
博联获取的小米电视红外码已测试无法通用于魅族遥控器,有大神提取的可用于魅族遥控器的吗  麻烦分享下
GMT+8, 2025-12-15 23:57 , Processed in 0.632079 second(s), 12 queries , MemCached On.
