查看: 2677|回复: 0
[求助] WS2812 怎么改变默认开灯效果,不是None
发表于 2021-11-12 22:48:31 | 显示全部楼层 |阅读模式
1  WS2812  在HA里开灯默认是NONE的,如何设置开灯默认是effect效果? 我查了esphome里面的代码好像是没有例子说明。。高手问回复一下怎么改代码?2  同样在Node Red 里面我只是懂开关灯。 怎么设置效果?   JSON 代码怎么设置效果?
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: D8
    num_leds: 33
    rgb_order: GRB
    name: "126 FastLED WS2811 Light"
    effects:
      # Use default parameters:
      - random:
      # Customize parameters
      - random:
          name: "My Slow Random Effect"
          transition_length: 30s
          update_interval: 30s
      - random:
          name: "My Fast Random Effect"
          transition_length: 4s
          update_interval: 5s
      - addressable_rainbow:
          name: Rainbow Effect With Custom Values
          speed: 8
          width: 50
      - addressable_scan:
      - addressable_scan:
          name: Scan Effect With Custom Values
          move_interval: 1000ms
          scan_width: 2
      - addressable_twinkle:
          name: Twinkle Effect With Custom Values
          twinkle_probability: 5%
          progress_interval: 4ms
      - addressable_fireworks:
          name: Fireworks Effect With Custom Values
          update_interval: 32ms
          spark_probability: 10%
          use_random_color: false
          fade_out_rate: 120
GMT+8, 2025-12-22 05:46 , Processed in 0.317712 second(s), 7 queries , MemCached On.
