查看: 3416|回复: 5
[求助] 自带的 Synology DSM 集成连接不上
发表于 2021-11-10 20:29:29 | 显示全部楼层 |阅读模式
版本:Home Assistant 2021.11.1
集成管理中自带的 Synology DSM 连接不上。  换多个帐号也连不上。不知道问题出在哪里,麻烦各位老师们帮我看一下。
ha小白,才开始折腾。
日志信息;
Logger: homeassistant.components.synology_dsm.config_flow
Source: components/synology_dsm/config_flow.py:190
Integration: Synology DSM (documentation, issues)
First occurred: 20:19:07 (26 occurrences)
Last logged: 20:22:34
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'ConnectionError = <urllib3.connection.HTTPConnection object at 0x7f1dc8f9ca90>: Failed to establish a new connection: [Errno 111] Connection refused'}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'ConnectionError = <urllib3.connection.HTTPConnection object at 0x7f1dc8530ee0>: Failed to establish a new connection: [Errno 111] Connection refused'}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'ConnectionError = <urllib3.connection.HTTPConnection object at 0x7f1dc8527a60>: Failed to establish a new connection: [Errno 111] Connection refused'}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'ConnectionError = <urllib3.connection.HTTPConnection object at 0x7f1dc8f75640>: Failed to establish a new connection: [Errno 111] Connection refused'}
{'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'ConnectionError = <urllib3.connection.HTTPConnection object at 0x7f1dc8f91220>: Failed to establish a new connection: [Errno 111] Connection refused'}
发表于 2021-11-10 21:16:41 | 显示全部楼层
集成? DSM集成? 那个还是别用了 新手建议你用VMM吧
发表于 2021-11-11 00:41:31 来自手机 | 显示全部楼层
楼主说的是HA里的DSM集成,不是DSM里的HA套件。
 楼主| 发表于 2021-11-11 19:44:38 | 显示全部楼层
连接失败,求助
发表于 2023-2-22 22:46:15 | 显示全部楼层
我的也是,管理员账户和新建的账户都无法登陆
发表于 2024-7-31 19:29:07 | 显示全部楼层
你们有解决的吗,群晖7.2系统,hassos7.4,也是DSM组件连接失败
GMT+8, 2025-12-17 13:18 , Processed in 1.079917 second(s), 15 queries , MemCached On.
