查看: 2611|回复: 1
[求助] 帮忙看一下下面这个esphome的嵌套条件语句哪里有问题
发表于 2021-11-8 21:51:25 | 显示全部楼层 |阅读模式
  - platform: vl53l0x
    update_interval: 350ms
    long_range: true
    on_value:
        then:
            - if:
              condition:
                binary_sensor.is_off: toilet_status
              then:
                  - if:
                    condition:
                        for:
                            time: 12s
                            condition:
                                lambda: 'return id(sens_1).state < 0.68f;'
                    then:
                        - wait_until:
                            for:
                                time: 2s
                                condition:
                                    lambda: 'return id(sens_1).state > 0.68f;'
                        - switch.turn_on: water_open
                        - delay: 4s
                        - switch.turn_off: water_open
                        - delay: 1s
                        - switch.turn_on: water_close
                        - delay: 6s
                        - switch.turn_off: water_close
我说one item里面有2个actions,所以出错,单看了一下是嵌套的if语句,为啥错了呢?
 楼主| 发表于 2021-11-9 11:18:39 | 显示全部楼层
好像是用了破折号的原因,把if前面的两个破折号去掉就行了
GMT+8, 2025-12-22 05:47 , Processed in 0.371521 second(s), 5 queries , MemCached On.
